Question about E-Machines T6524 PC Desktop
Problem with cpu
When i switch on the power supply, within a few seconds a continous buzzer goes on and remains loud as long as u wait, with no further progress.
    President:
  • 828 Answers
You mean a long beep, usually this problem is VGA Card or Memory is not properly connect to the motherboard, remove it and put it back again switch on your PC.
Posted on Jul 29, 2009
I have a 1989 Toyota Corolla DLX 4dr, fwd. The car was running and starting fine (drove it to the store this morning) and when I go to move it later to let my roommates out of the driveway, the car wont...
Battery very weak
Alternator not working
Bad connections at battery posts, or bad connections on ground cable
If you can jump the car to start it, and it will stay running, take it to Advance Auto, Auto Zone, O'Reilly's, etc and have them test your battery/alternator.
Mar 12, 2017 | Toyota Corolla Cars & Trucks
Desktop shut down in few seconds after getting display
Good day,
The problem you describe is probably due to a faulty power supply.
The four pin connector which you unplugged supplies power to the CPU, which means you will not be able to get a display with it plugged out, as there will be no power to your CPU.
The fact that the PC does not shut down when removing the 4 pin connector strengthens the evidence that your power supply is faulty. By removing the 4 pin connector you are reducing the power required from the power supply to the point where it is not 'overloaded' enough to switch off.
You can test this by plugging in the 4 pin CPU power connector, then unplugging something else, such as the DVD writer.
Then switch on your PC and see if it still shuts down.
If it remains on then the cause of your problem is definitely the power supply.
Replace the power supply and make sure it has a wattage rating of 400 watts or more. These power supplies are relatively cheap, and should be available at your local PC store for about $15.
Best wishes,
Graeme.
Apr 30, 2013 | Computers & Internet
GE chest type freezer buzzer going off
If you have a fast freeze button try that and see if the alarm goes off within a few hours. It bypasses the thermostat switch. Check condenser clean etc but be prepared for compressor failure
May 19, 2012 | GE Freezers
Lambda ews600-18 voltage goes down.
there is a short circuit protection and overoad protection to smps so o/p capacitor may short or secondary diode may short .so check voltage at primary when switched off after 33seconds whether switching process is going or not for that check dc volt at i/p capacitor then check volt at collector of transistor if metr shows 1digit then switching is going if not then meter shows full dc volt check component near about that
Apr 13, 2010 | Lambda 40-Watt Power Supply
I have HP 305W. When turns on the power, it stops within 5 scnds
sounds like your motherboard lost a control chip. that makes the power supply cycle off, when m/b doesn't send correct signals to continue boot.
Nov 27, 2009 | HP Computers & Internet
Unknown error
Re-seat Video card, replace memory.
Feb 17, 2009 | E-Machines eMachines Desktop PC
When i turn my CRT on, after a few seconds my screen goes blank, then displays again, while this thing is happening, i can hear something switching... power led is on(green)... even when the display goes...
It sounds to me that the monitors power supply is dying. I would replace it with a different monitor as soon as possible. I would consider this a dangerous situation, and a possible fire hazard.
Thanks for using FixYa,
Hope this helps,
Eric
Dec 11, 2008 | ZT Group CISNET A7050 PC Desktop
Computer will power up for three seconds then shut down
Had the same problem on a few motherboards, check your capacitors very closely. If they are rounded or split on top they are bad. You can change the capacitors with new ones to fix your problem but it often ends up costing as much as buying a new board.
Nov 08, 2007 | Intel D101GGC Motherboard
E-Machines T6524 PC Desktop Logo
81 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
