Question about Kodak EasyShare C913 Digital Camera
Where can I get A replacement battery door for Kodak c913
  • 724 Answers
I have the kodak easy share c913 my camera turns off when i try to use the zoon button
please make sure that you're using fresh batteries. remove battery then press and hold power button for 30 seconds. reinsert batery and try to power on and use zoom functions
Sep 06, 2010 | Kodak EasyShare C913 Digital Camera
Could i buy a battery door for my kodak easy share c913 dgital camera
Here's one source, in several colors:
http://uscamera.com/c913.htm
Aug 16, 2010 | Kodak EasyShare C913 Digital Camera
I just put new batteries in my kodak easyshare c913 but will not turn on
Make sure you are using rechargable batteries. Normal batteries are not strong enough. Try using either rechargable Lithium Ion batteries, or rechargable Nickel Metal Hydride (NiMH) batteries. These are much stronger and should give you a good battery life.
Let me know if this helps :)
Feb 27, 2010 | Kodak EasyShare C913 Digital Camera
The battery door on my Kodak EasyShare C913 is cracked and falling apart. I have only owned this for about 3 months. Can this be replaced? Where do I find the replacement part?
You will have to send it in for repair. Good news is that if you haven't dropped it or had it in contact w. water this will be free of charge.
Just have your model no. contact details and serial no. ready and KODAK will be able to arrange all the details for you.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 01, 2009 | Kodak EasyShare C913 Digital Camera
When i put my kodak C913 digital camera on it goes off again
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Kodak EasyShare C913 Digital Camera
Need to know how to repair easyshare c913 battery door has little metal piece connecting the battery -it is broken can i buy just the piece?
go to this website
http://www.uscamera.com/2f7049.htm
part for your camera
its a battery compartment for C813 which is compatible for your C913 Camera
Sep 22, 2009 | Kodak EasyShare C913 Digital Camera
I have a kodak camera ( C913 ) Ive had it a couple of weeks and now it wont switch on , but it switched on about 2hours ago , What shall i do
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Apr 10, 2009 | Kodak EasyShare C913 Digital Camera
Kodak EasyShare C913 Digital Camera Logo
81 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
