Question about HP LaserJet 3055 All-In-One Printer
I am not able to print it shows "52 scanner error restart printer
Even if i restart the printer it shows the same message
    President:
  • 3,278 Answers
From HP Support:
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the all-in-one to initialize.
If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. Use the power switch to turn the all-in-one on.
If the error persists, contact HP Customer Care.
Hope this helps.
Posted on Aug 11, 2009
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
HP LASERJET M1132 52.0 SCANNER Error how to fix it
a 52 scanner error indicates that the laser scanner that writes the image to the page is bad and will require replacement.
Oct 13, 2014 | HP Office Equipment & Supplies
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
My HP LaserJet P3005n, is not working properly whenever I want to print it initializes and then show Error 52 message.
52.00 ERROR
A scanner motor error has occurred.
Scanner motor rotation is verified at the initialization of a print job.
1. Verify that the scanner motor connector and the ribbon cable from the ECU are firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in connector J403 on the ECU is fully seated.You must remove the ECU in order to verify this connection.
4. If the message persists, replace the laser/scanner assembly.
Jul 26, 2011 | HP LaserJet P3005 Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
52 scanner error turn off and on is displayed in the contoll panel,the same thing is again displayed if i turned off and on also nothing can be printed due to this displey. please help
The printer has burned a scanner assembly. The part number is RM1-2033-030CN. The part is extremely expensive in relation to the printer cost. ($182.00 @ HP)
I would recommend surfing ebay for an HP Laserjet 1022 printer as it is the cheapest printer that has the same scanner. Even a dead 1022 will work as they tend to either have formatter or fuser issues when dead. A scanner error on your printer or the 1022 is extremely rare.
I have included a link to the HP 3050 service manual for you that will walk you through it step by step. The teardown is significant however very do-able by the novice with the service manual.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/service.html
Good luck, You can do it.
Jul 09, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
