Question about HP DeskJet 5652 InkJet Printer
I-4308 Datamax printer connection problems
I have one datamax I-4308 printer, and I connected it to my laptop to print ,it works well for almost one year ,but it recently the computer also appears that it can not be connected to the printer , I changed to use one new USB wire ,but the problem still exisits ,
any answers ,please send me email thanks a lot
First you do not change the usb cable connect the printer cable into another usb poart. if it is same than your printer is connected to other computer if it is working problem is printer ports.
Posted on Nov 23, 2007
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Toshiba continuous printing extra label printing
If connected to a pc use the pc to tell it to cancel all printing.
Oct 18, 2013 | Datamax I-4308 DT/TT Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
I have a datamax I series and I would like to know how to troubleshoot the stepper motor
What type of problem do you have?
Will the printer not feed?
There has been some troubles on early model of the Datamax I class printers that are detailed in a service bullitin on the driver/power supply.
If the printer feeds intermittently, or runs back wards(hunts) it is probably a board failure. I usually replace the board and the motor on exchange with DAtamax if under warranty.
Jan 21, 2011 | Datamax I-4308 Thermal Label Printer
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped...
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
Jun 05, 2010 | Datamax I-4308 Thermal Label Printer
Printer stays in a SND mode
Have you check the firmware issue?
Nov 05, 2008 | Datamax I-4308 Thermal Label Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
HP DeskJet 5652 InkJet Printer Logo
70 people viewed this question
Ben Johnson
