Have a ba fairmont ghia 2003 v8 that has been written off by being run up the backside, also have a 2003 ford ba 6 cyl so am wondering if i can do engine swap and convert the 6 cyl into the v8??
SOURCE: Its sounds like a thump from back diff
If you have a 4x4 most likely your rear axel bushing is cracked, no big deal, just swing by your nearest Toyota dealer and order it. it goes for about $120. Easy to replace, use wd4 or nutsoff to spray inside the car body a few hours before trying to replace it. The accumulated dirt and road salt make it very hard to take the two long bolts out without a ¨fight¨. Please make sure you use a support jack to hold the rear axel in place when you get the bushing out.
Good luck.
SOURCE: engine runs rough in gear.
Okay disconnect battery for 3 min to reset engine light to turn off! change wire #2 to #3, Swap them then start it. if misfire happens again if your fault codes goes from po302 to po303 then your ignition wires should be changed!!! if it is the same the that side of coil might be at your point of interest to change but I think spark wires might do it!!!! spark plugs should be the same time!!!! I think this will help??
SOURCE: 1998 ford motor swap 8cyl to a six inline
Unfortunately, You will need to Change it all. None of the V8 Components will Transfer to the Inline 6. Please Rate My Response! Thanks!
SOURCE: 1996 Ford F-150 300 inline 6 timing gears/timing issue
u have to unplug the spout small gray plug on driver side in the eng comp . on the fender wall on plug that set timming thing it should b 10 deg b4 top dead center then plug spout back in comp will adv timming
SOURCE: need wiring diagram for 1988 jeep comanche 4x4 6
check the solenoid on the starter it powers the ign for starting then switches to run when you let off key,either the solenoid is bad or a wire to the solenoid has come unhooked and sometime they have an in line fuse which can blow.
