Question about The Optics
I need a new Battary case for my Fujinon 14X40 TS1440 Techno-Stabi to whom should I apply and how can I send the money.
  • Anonymous Dec 19, 2018
    Baker Marine in San Diego carries them
    www.bakermarineusa.com
    Top Expert:
  • The Master
  • 53,745 Answers
Apply to the manufacturer spares section and pay with paypal
Posted on Oct 24, 2017
SOURCE:
Dust removal inside fujinon techno-stabi binocular
The case has to be opened for this, and a can of compressed air used. There is the risk that the binocs can be knocked out of collimation, so you'd best ask a repair tech for a quote.
Sep 19, 2016 | Fujinon Techno-Stabi Binocular
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Aug 28, 2011 | Fujinon Techno-Stabi Binocular
I purchased a Fujinon 3.5-10X50 rifle scope a few years ago and mounted it on a Remington 7 MM Mag. I am unable to pull a group less than 12 inches at 200 yards and have not been able too since installing...
It is most likely the mounts not the scope. I would just install it on the new gun and check it there. Most times a scope that wanders is the mounts. One thing with big scope is they need to be tight or the recoil will move it in the mounts. Next due to being tight when the gun heats up it can and will tweak the scope in the mounts enough to move your center. Try it in your other gun, try 3 shot groups and let the gun cool. Recheck your center. If it is good with a cold gun all is well. If it moves from one day to the next it is the mounts. If you count the clicks to recenter, come back the next day and move it the same clicks, it is the mounts. If it is all over the place, day after day it is the scope.
Jan 21, 2011 | Fuji non 4-12x42mm Rifle Scope
Fujinon Technostabi 14x40--battery compartment,clip that holds battery in place broke off,need new battery compartment
I had this problem a couple of years ago. I bought a new battery compartment from Fujinon's US repair center: http://www.bakermarineusa.com. It was about $38. Unfortunately I now have the same problem with the new battery compartment. I'd like to find a source of the metal spring clips.
Nov 28, 2009 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Broken rubber seal on batterie cover
Goto auto shop. any name. grab a tube of permatex, blue red don't matter. this seals better then sillacone. sronger lasts longer. put a vare thin bead around the cover. NOT to much abut the same as the old seal. Now let that sit over night, be for putting it back together, or it'll be a real pain opening it back up. this will keep everything out. I've dun this more then once. good luck.
Mar 20, 2009 | Fujinon Techno-Stabi Binocular
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Repair Techno-stabi binoculars 12X32
I have a set of Minolta pocket binoculars. One side rattles and is hard to see out. One side gets great vision. Where can I get this repaired. They are the set with the zoom.
Aug 15, 2007 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Optics Logo
171 people viewed this question
Top The Optics Experts
vince
geob91
Israel Pineiro Jr
Are you a The Optic Expert? Answer questions, earn points and help others
