SOURCE: pilot goes out when fryer reaches set temp. and shuts-off.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
SOURCE: A/C set to "AUTO" but still won't turn off after temp is reached
you have either a bad thermostat or bad controls in the units unplug the furnace make sure the outside unit shuts off turn off the thermostat plug back in if it all starts with the thermostat off you will need service thanks for the high ratting keeps me helping for free.Tom
SOURCE: Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
SOURCE: Pitco 35C+ fryer. Pilot lights fine; main burner
Its a simple design. If the thermophile does the work of powering the fryer control. Do you have a good pilot flame? If the pilot flame ain't good enough then the millivolts won't be enough to operate the solenoid on the gas valve. Most folks replace both the pilot and thermophile on these fryers since the grease makes such a mess of everything. If the pilot generator is fine then the gas valve is next.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
