The extended service is probably with an insurance company sold by sears so you may have to read the policy and see if you need to contact a service agent for the repairs and then send the account to the company
Most (except German and Asian brands) are made by Whirlpool and are very similar inside. Sounds as though your main motor is gone. YouTube has excellent videos showing how to disassemble. When I did mine, the new motor had same part number as old one, but old one was 1/6 HP and new one was .24 - almost 50% more power.
SOURCE: I require parts for a
Try calling the number below - we managed to get parts for our portable dishwasher (after a considerable wait).
Dan by Products Inc.
1-800-263-2629
Ext. 212
1-419-425-8627
Fax: 1-419-425-1244
SOURCE: dishwasher was making terrible grinding
Remove all the filters and looking down into the sump, at approx 10 o'clock you should see a plastic cover with a tx20 screw. Remove the screw and cover, this will expose the pump impellor, check it is free and remove any obstruction (caution advised as there may be a shard of glass etc). With the cap off set a cycle, close the door and immediately open door and reset the unit. (check how to do this from your user manual, usually holding the start button for 5secs, or pressing two buttons simultaneously marked by a line and two dots on the selection panel but models vary). You should hear the pump run and any debris will be expelled into the tank. Check the impellor again, replace the cap and screw. Do a visible check of the tank to see if any obstruction were 'spat out' by the pump. Check your outlet pipe, particularly if it is attached under the sink via a spigot for blockages. Run a prewash or quick cycle to test. I really hope this solves the problem, if you need to repost or comment for additional advise please add the full Enr number. All the best and good luck
SOURCE: Hello, I have
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: Service a DVD player in Victoria, B.C.
depending on cost of player may be cheaper to replace than repair---Best Buy etc do repair some equipment---getting parts for most of these units can be impossible and repair usually exceeds the cost of replacing the player.
