Question about Belkin (F5D5231-4) Router
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I was connected wirelessly just fine for months.
    Problem Solver:
  • 18 Answers
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Posted on Jul 29, 2009
  • Bradley Wales Jul 29, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Getting disconnected
Need more INFO... getting disconnected from what ??? the LAN (Local Aria Network) or the WAN (Wide Aria Network) ???, in other words do you loose network connectivity or internet connectivity ???, is it trough wired or wireless connection ???, if it's wired LAN connectivity, check/change the cable from the router to the computer, if it's wired WAN connectivity, check/change the cable from the router to the ISP's modem, if it's trough wireless check for RFI (Radio Frequency Interference) or EMI (electromagnetic interference) move the unit away from any electrical device or radio transmitters, change the frequency of the unit to an other frequency than the default one, etc...
Feb 09, 2011 | Computers & Internet
Routers modem light keeps flashing and booting me off line but when i hard wire computer to modem as i am now it works fine. changed cables and reset computer and modem
Flashing lights on a router are routine - they indicate connectivity and traffic.
Seems to me the simple answer here is stay connected by wire. Wire runs much faster than wireless. Wireless is 10 <> while wire is usually either 100 or 1000. If you have to have wireless, do a hard reset on your router and also reload the drivers. Check with the manufacturer for any soft or firmware grades they may offer. If you find a firmware upgrade - make sure you understand the instructions before you start. If you fail in this department, you will have to replace your router. Had you given a little more information on this, I could have done better with links and such.
Mar 03, 2010 | Computers & Internet
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
My router is connected to the modem but there is no internet connectivity?
Modem brand/model?
Router brand/model?
Type of internet connection coming in to your modem, DSL, Fiber, BroadBand (Satellite/WAN)
Jul 24, 2009 | D-Link AirPlus DI-524 Wireless Router
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
No internet through router
** Try this steps
- Check physical connection (Modem=WAN Port, Computer=Port1) *should be hard wired connected*
- Power cycle modem and router for 2 minutes (to turn off the modem and router)
- Check web browser for Internet connectivity
* If nothing happen reset the router for 15 seconds and try the steps again.
Feb 14, 2009 | D-Link AirPlus DI-524 Wireless Router
Signal found, but no connectivity
Try this. It should renew your configuration between your router and your internet provider:
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The 192.168.0.1 address is NOT on the internet. It is the address to the router itself.
Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
Step 3 Click on Status. Under WAN, Click DHCP Renew. If it does not get an IP address or times out, then continue with Step 4.
Step 4 Power cycle the cable modem and router:
Turn the cable modem off (first)
Turn the router off
Leave them off for 2 minutes**
Turn the cable modem on (first)
Wait until you get a solid cable light on the cable modem
Turn the router on
Wait 30 seconds
** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Step 5 Follow Step 1 again and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not already have a public IP address under the WAN heading, click on the DHCP Renew and Continue buttons.
If you're still getting no connection to the internet, another alternative (before chucking the router) would be to reset it to factory defaults, and run through the setup process again, from scratch.
Cheers
Nov 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Dec 22, 2006 | ASUS WL-500g Wireless Router (WL500GDLX)
Belkin (F5D5231-4) Router Logo
276 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
