Screen adjust? My Sanyo TV CM29FS2 is doing a larger picture than screen measure.How can I adjust it? Thanks!
  • 269 Answers
Chec for open bias resistor or leaky capacitor
Posted on Jul 31, 2009
Have just hooked up Sanyo tv model DP32648 to sattlelight receiver. Picture is larger than tv screen. How do I fix
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done./
Apr 01, 2018 | Sanyo Televison & Video
The picture is in the middle of the screen on my sanyo tv. Is the tv playing out or can I fix it?
could be or the aspect ratio has changed
get the on screen menu up and find the scree aspect ration using the volume buttons adjust till the picture is full screen with the figures the right size( not tall and skinny or short and fat)-- ok then exit
Jun 09, 2016 | Sanyo Televison & Video
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
My sanyo tv doesnt have the remote and i need t adjust the screen so that i can see the whole picture
U can't do these kind of adjustments without the tv original remote sorry.Try website like Remotes.com to buy the tv original remote to used.
Aug 31, 2011 | Sanyo DP32746 32 in. LCD Television
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
There's a picture on the screen, but it has lines all across it.Sometimes it will be clear, but most of the time it has lines. I also have directv, but they've installed a new box. Is this my television...
Hello
If the lines are there, and are across the screen at about an inch apart the whole screen from top to bottom, it is due to a slight increase in your TVs screen votage. It can be adjusted.
Open the back cover of your TV. There is an LOT [Line Output Transformer], can be seen directly soldered to the printed circuit boar of your TV. It is the largest component inside your TV, which have usually three wires emerging from it, and one thhick wire goes to the final anode of the picture tube, and will seem to be sticked to the top of the picture tube with the help of a rubber ******. Other two wires goes to the base card of the picture tube, a circuit board.
The said [LOT] has two controls integrated on it facing you as you open the TV. Among the top one is focus control, and the bottom one is screen control. Both of them are variable resistors, help to adjust focus and screen voltages respectively.
As set powered on, keeping the brightness, contrast and colour controls to its minimum, turn the screen control a little bit counterclockwise [not more, a little bit] will eleiminate the lines on your TV screen.
Take every precautions we have to, when working with an electrical equipment. Keep children away from you while you are working on it. Never allow them even to come beside you. Keep an adult beside you as a precautionary measure. Ok.
Wish you all sucess.
Oct 24, 2010 | Sanyo HT28745 28" TV
How do I adjust the screen to the TV - I've looked in the MENU options and can not adjust the height of the screen. In other words - I can not read the score ticker on the bottom of the screen
Your sanyo tv may have service mode adjustments. It can be taken according to the sevice code options, which can be get from service journals available in the market. no menu adustment is there to adjust the picure linearity, height , subbrightness control so on. All adjustments are coded and have critical measurements which can be adjusted through service mode with the help of remote control. The remote control should be orginal to access service mode. Duplicate may not work properly.
Oct 14, 2010 | Sanyo DS24425 24" TV
The picture is larger then the screen and we can't see the full picture
Check the Aspect or Picture size settings on your Sanyo remote control and/or your HD cable box.
Mar 02, 2010 | Sanyo DP50747 50 in. Plasma TV
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
