Question about Cameras
Will not stay on
Lens is out and will not retract.  Polaroid screen displays for a five seconds and green light flashes.  Camera turns off.  This looks to be a common problem with no solution.  Is there a way to reboot or reset the unit?
  • 586 Answers
When the zoom motor start malfunction then this error shows, to rectify this problem you have to replace the zoom motor(if component level repair is available) or you have to replace the optical zoom lens complete assembly. After replacement your camera work fine again.
Thanks for using fixya.
Posted on Jul 29, 2009
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
The lens is not retracting
i have a samsung s730 and when that happens to me i put new batteries in it and it works
Apr 02, 2009 | Polaroid i830 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
My Polaroid i533 digicam won't turn on
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
Aug 14, 2008 | Polaroid I533P Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Problem with i531
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
Nov 18, 2007 | Polaroid i531 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Cameras Logo
75 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
