SOURCE: Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
SOURCE: no sound coming from speakers.
Did you run the audio cable from the computer to the monitor. If not you must have that for the speakers to work. If yes can you verify computer output with another pair of speakers to narrow it down to computer or monitor. If it is the monitor built in speakers that are the problem reply and we can go through a procedure to get them working.
SOURCE: Compaq JBL Platinum Series speakers
Make sure that you got 12v 1.0 A adapter. Not .01 A. They have one at newegg.com atrix DVCPA1AA power adapter-12v 1.0 A. you should not need drivers for speakers. Make sure you got it pluged into right port if you got the adapter. Also make sure under control panel under sound that you got it setup for two speakers.
SOURCE: Peavey floor monitor speakers
you can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
