Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 ftr keeps flashing code 12 - Rinnai EnergySaver 556 Air Conditioner
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Posted on Jul 29, 2009
Rinnai 556 WT gas space heater flashing PF
most modern gas heaters use a code system to tell the operator what the problem is. look for a pattern in the flashing, and then compare that pattern to the literature on the inside of the heaters panel. When you have a diagnosis code, you can follow the appropriate course of action.
Nov 20, 2013 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Filter light beeping n flashing on a rinnai 556 ftr
Tara, generally that means the filter needs to be removed and cleaned. However, the electric part of the unit must be turned OFF and unplugged, before the filter is removed for cleaning, The unit should remain that way, until the filter is replaced. Then plug the unit back in, turn the Master ON/OFF Switch to ON and the unit will revert back to its original factory settings. From there, you can set it however you like.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Heating & Cooling
My Rinnai 606tr Silent Server continually shuts down and the number 12 appears on the display screen. What's up ?
I know that this is an old post but i had this same problem and i cant find a single answer to this problem anywhere on the net. Rinnai couldnt even give me an answer (let alone even call me back)
Well I figured it out. If you go onto Rinnai's website, you can download the manual, which has the codes and what they mean. Code 12 means Flame Failure. Still this didnt tell me enough. After taking the thing completely apart twice i finally figured out that the heater itself was perfectly fine.
The gas line was the problem. My gas line has a check valve on it right next to the heater. The check valve was not letting a consistent flow of gas to the heater because the heater was drawing too much gas at times, causing the check valve to start to close because it thought there was a leak (so to speak).
All i did was turn the gas valve behind the heater so that it was closed more (not letting as much gas flow through) so that it wouldnt trip the check valve. the heater now works fine and keeps a consistent temperature with no problems.
Jan 05, 2010 | Rinnai EnergySaver 556 Air Conditioner
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes. rinnai.us, look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Our heater seems to have therostat set low. We are cold.
not sure if this unit has any type of sensor to protect you from carbon monoxide but if it is ventless and operates on gas it may be tripping on sensor any ventless unit must be operated with fresh air for combustion
Apr 06, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
556-P Error code 53
I would recommend you read this, hope it helps:
Rinnai Recalls Wall Furnaces Due to Carbon Monoxide Hazard
clip this post email this post what is this?
see most clipped and recent clippings
Posted by saltcedar (My Page) on Thu, Feb 21, 08 at 19:28 NEWS from CPSC
U.S. Consumer Product Safety Commission
Office of Information and Public Affairs
Washington, DC 20207 FOR IMMEDIATE RELEASE
February 21, 2008
Release #08-199
Firm's Recall Hotline: (866) 746 8344
CPSC Recall Hotline: (800) 638-2772
CPSC Media Contact: (301) 504-7908
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in
cooperation with the firm named below, today announced a voluntary
recall of the following consumer product. Consumers should stop using
recalled products immediately unless otherwise instructed.
Name of Product: Direct-Vent Wall Furnaces, Models RHFE 431 and RHFE 556
Units: About 52,000
Manufacturer: Rinnai America Corp., of Peachtree City, Ga.
Hazard: A gasket in the unit can fail, posing a risk of poisonous carbon
monoxide gas leaking into the home.
Incidents/Injuries: Rinnai has received 11 reports of carbon monoxide
leaking from the furnace. No injuries have been reported.
Description: The recall involves Rinnai EnergySaver Direct-Vent Wall
Furnaces, Models RHFE 431 and RHFE 556. They are either natural gas or
LP gas (propane) fueled. The following model numbers are included in the
recall:
Model RHFE-431: FAIII-N, FAIII-P, WTA-N, WTA-P, WTA-72B-N, WTA-76B-N
Model RHFE-556: FAIII-N, FAIII-P, WTA-N, WTA-P
The model number is printed on the top of the rating plate located on
the right side of the unit. The recall includes only those units
manufactured from February 2000 through December 2007. The manufacturing
date code is the first four digits of the serial number, written as YY
MM, and is located at the bottom of the rating plate.
Sold through: Wholesale distributors nationwide to contractors and
dealers from February 2000 through December 2007 for between $1,600 and
$1,900.
Manufactured in: Japan
Remedy: Consumers should stop using the furnace immediately and contact
the firm to arrange for the installation of a free repair kit.
Consumer Contact: For additional information, contact Rinnai toll-free
at (866) 746-8344 anytime, or visit the firm's Web site at
www.wallfurnacerecall.com
To see this recall on CPSC's web site, including pictures of the
recalled products, please go to:
http://www.cpsc.gov/cpscpub/prerel/prhtml08/08199.html
The U.S. Consumer Product Safety Commission is charged with protecting
the public from unreasonable risks of serious injury or death from more
than 15,000 types of consumer products under the agency's jurisdiction.
Deaths, injuries and property damage from consumer product incidents
cost the nation more than $800 billion annually. The CPSC is committed
to protecting consumers and families from products that pose a fire,
electrical, chemical, or mechanical hazard. The CPSC's work to ensure
the safety of consumer products - such as toys, cribs, power tools,
cigarette lighters, and household chemicals - contributed significantly
to the decline in the rate of deaths and injuries associated with
consumer products over the past 30 years.
To report a dangerous product or a product-related injury, call CPSC's
hotline at (800) 638-2772 or CPSC's teletypewriter at (800) 638-8270, or
visit CPSC's web site at www.cpsc.gov/talk.html. To join a CPSC email
subscription list, please go to https://www.cpsc.gov/cpsclist.aspx.
Consumers can obtain this release and recall information at CPSC's Web
site at www.cpsc.gov.
Mar 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556 Air Conditioner Logo
1,569 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
