Question about Lightning Audio S3.10.4 Car Subwoofer
Need help im planning to build a enclosure for my s3.10.0 subwoofer, can someone advice what type of enclosure and what size it will be. Tnk u very much! hoping for good advice.
  • 655 Answers
Hello marne_glenn,
Here's a link to Lightning Audio's manual for the S3.10.4.
The minimum recommended size for a sealed enclosure is .5 CuFt. There is no recommendation for ported.
Hope this helps.
Posted on Jul 29, 2009
Need some tips on building a subwoofer box.
Do some research on the model of subwoofer and find the recommended box size, subwoofers need the correct box size to work to its full potential, and size in meaning the volume of space inside the box so if you cant fit your box in your trunk cut it down to the size you need but make it bigger as much as you took of if you have more room say in night for eg.i hope the heaps otherwise there is so much online about sub enclosures.
Aug 06, 2014 | Car Audio & Video
Recommended enclosure for maxp154d
Send me the type and model of vehicle it is going into. From there we can determine what type of sub box to build.
Jan 31, 2012 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Does anyone know the actual airspace requirements for sealed and ported enclosures on these speakers? Please no idiots building cube boxes need to respond!
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Feb 17, 2011 | Autotek MX-1222 Car Subwoofer
I Need To Know What Size Box to Build.. To Get The Best Sound Out OF The R 10's
Depending on the amount of speaker that you have, Alpine recommends that you use anywhere from .85 cubic feet to 1.25 cubic feet per subwoofer. This choice will be reflected by the sound of your subwoofers. If you choose to use .85 cubic feet per subwoofer, you will get a tight sound without excessive cone excursion.
However, if you decide to use 1.25 cubic feet per subwoofer, your subwoofers will hit lower notes and be able to handle more power.
These are factors that you, as a listener, will have to bear in mind when choosing a subwoofer enclosure. Regardless, enjoy your speakers!
Jan 16, 2011 | Alpine Type-R SWR-1042D Car Subwoofer
What size should i make the enlcloser
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed. You will need approx 2 cu ft
To tune this 2 cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome
Dec 02, 2010 | Jensen XS-1010 Car Subwoofer
Hi i have a 15"w3-d4 jl audio sub,can anyone tell me what size antype box i should use ie sealed or ported and the box dimensions
I've had a look at the JLaudio website and they recommend 2 box designs, a ported and a sealed.
The sealed box needs a volume of:
2.125 ft3 or 60.2 litres.
To get this you would need to build the box to these dimensions:
22" x 16" x 14.75" or 559mm x 406mm x 375mm
The ported box needs a volume of:
3.50 ft3 or 99.1 litres.
24" x 19" x 18" or 610mm x 483mm x 457mm.
The port needs to be:
3.0" x 10.9" or 76mm x 277mm.
The enclosure recommendations listed above are external dimensions which assume the use of 3/4" (19mm) thick material. If you are using 5/8" (16mm) thick material, subtract 1/4" (6.5mm) from each dimension. Do not use any material with a thickness of less than 5/8" (16mm) as this may compromise the rigidity of the enclosure.
• All enclosure volumes listed above are net internal volumes! Driver displacement, port displacement and brace displacement must be added to obtain the final gross internal volume. All enclosure dimensions above have already taken this into acount.
• When using two subwoofers in a common enclosure simply double the required volume and, in the case of a ported enclosure, use two times the recommended port(s). Likewise, when using three subwoofers in a common enclosure simply triple the required volume and, in the case of a ported enclosure, use three times the recommended port(s).
• We recommend the use of this speaker in a bi-amplified system using high-quality satellite speakers and a high-quality amplifier. We do not recommend the use of this subwoofer with a passive crossover (coil), as this type of device will adversely affect performance.
As you can see it all depends on the space you have available, whilst the vented box will give you a more efficient bass responce especially with the low range frequencies.
If you to go and look at the information about your sub woofer and find out all the information about building or buying the correct enclosure then this is the link to the pdf file I found:
The enclosure info is on page 3:
JL AUDIO 15W3 Tech Specs and box info.
Warm regards
Mike
Oct 12, 2010 | Jl Audio 15W3-D4 Car Subwoofer
I am building a custom box for 2 15 inch Kicker L7's. These will go in the trunk of an 04 Impala. Do I need 4 or 5 cubic feet per chamber in a ported box? Also, what size port should I use? and how long? I...
Hello bgl6176,
According to their specs, the L7's will work in a ported enclosure with as little as 3 CuFt and up to 6 CuFt. Usually with ported, bigger is better, so let's use the 5 CuFt per chamber. I'm assuming that you have room for a 10 CuFt box in the trunk? That's a big box? Almost half as big as a medium sized refrigerator. I hope you don't plan on putting your golf bags in there too. For 10.15 CuFt, a box will need to be 36X29X20, allowing 0.15 for the partition, sub, and port displacement.
To tune each chamber to 30Hz, you need a 4" diameter port 4.6" in length. Lots of custom builders use PVC and even ABS pipe for round ports. You can also buy "pretuned" ports from sites like www.partsexpress.com.
You'll have to measure the exact room that you have available and then adjust the dimensions accordingly.
Here's a link to a great site for calculating almost anything in box building and subwoofer related. You can use the old "multiply LxWxD and divide by 1728" and the other formulas too, but here you can plug the figures in and immediately see the results.
http://www.the12volt.com/caraudio/boxcalcs.asp#rec
Hope this helps.
Oct 18, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Want to find out the best type of enclosure for 2 lanzar max pro 124d subwoofers
you best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
heres a link that will give you the specs for your sub
http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
Sep 07, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
I bought a JL w7 and it didnt come with instalation plans where
What size is it and what is it your looking for ? Enclosure Specs, wiring is pretty straight foreward ... let me know... Mark
Aug 15, 2009 | Jl Audio 12W7 Car Subwoofer
Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Jan 05, 2007 | Sony XS-L1200B Car Subwoofer
Lightning Audio S3.10.4 Car Subwoofer Logo
80 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Mark Skinner
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
