Question about IBM Computers & Internet
Ibm thinkpad On start up I get error codes 00161 and 00163 I hit enter and get time and date screen enter again to add info and I get error codes 00161 00301 and 00163 and can go no further. HELP
  • IBM Master
  • 32,281 Answers
The 161 CMOS error means the CMOS/BIOS battery is dead/flat and needs to be replaced.
The 163 CMOS error means the Date and Time could not be updated when you change the Date and Time setting. This is caused by the flat CMOS/BIOS battery.
When you replace the battery with a new one, the BIOS will go back to the default settings, go into to BIOS setting (press F2 when you boot up) and change the Date and Time, then save and exit.
Posted on Jul 29, 2009
HI, I AM SANDIP FROM CENTRAL ACCOUNTS OF DURGAPUR STEEL PLANT A UNIT OF SAIL having IBM Thinkpad type 2682 ,Product Key GXR3W-GHM34-7RFFM-BVCQJ-WGF4G. PROBLEM- WHEN I AM SWITCHING ON THE POWER A ...
As soon as anything appears on screen after power-on, press F1 (keep clicking it until the BIOS setup screen appears). The first option on the list is Date + Time, click on that, and enter correct date/time. Then press F10 to accept + reboot. If this error happens again, it means that the CMOS battery (which keeps your settings alive) has died; it is cheap + easy to replace, however you have an R40 model, and I avoid working on Rxx series so that job may be harder. I could point you to the R40 service manual, which is very good to dis-assemble that laptop (it is necessary to lift keyboard to get to CMOS battery, which involves removing some screws from the bottom.
May 01, 2017 | IBM ThinkPad R40 2682 Notebook
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
Problem with ibm laptop
Error 0250 means that the BIOS battery is dead and has to be changed, they are usually located hidden in the memory panel underneath the laptop and can be covered in red, blue or yellow plastic.
To boot into windows hit the F1 key when you see the IBM logo, go into the BIOS utility and set the time and date, save the changes and exit the BIOS, make sure you have AC power plugged in when you do this as it will not remember the time and date and you will have to do it again.
Good luck.
Jul 01, 2009 | Lenovo ThinkPad R400 Notebook
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
How can I boot from USB in a Thinkpad T22?
I assume with "boot menu" you mean the BIOS boot menu (the one you get to if you press F12 during start up, before the Windows screen appears.)
  1. Go to "Enter Setup"
  2. Go to "Config", click "Enter"
  3. Go down to "USB", click "Enter"
  4. Make sure that "USB Bios Support" is enabled.
  5. (Hit "Enter" again and choose between "enabled" and "disabled")
  6. Hit "Esc" twice to go back to the main page.
  7. Go down to "Startup", click "Enter"
  8. Choose "Boot"
  9. Check if "USB CD" is in the list of boot options or excluded form booting.
  10. Hit F10, confirm any changes you made (click "Enter" for 'yes') and reboot.
  11. Tap or hold down F12 again and you should see the boot option menu again.
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is possible that the T22 BIOS does not support external booting. Check you version - the latest release from IBM is version 16ET32WW (1.12), release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
Jan 30, 2009 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
My IBM Thinkpad 770 will not start up
I have the same computer and I know exactly what you talikng about, the Off>On screen you get, the computer wants you to turn it off and then back on again, Just push the button to turn it off and then hit the button to turn it on, don't wait to long between turning it off and on again. it should just be a quick off and quick on.
Sep 24, 2008 | IBM ThinkPad 770 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
Troubleshoot IBM laptop
The answer is very simple, Use Restore disc to Reinstall the Operating system.
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
569 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
