SOURCE: Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
SOURCE: Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
SOURCE: Error message 5C10, won't print. Need locations
I think there was a broken pieces of hardware in the print carriage.
According to the Canon Center this one cannot be fixed. If your printer is under warranty, send it to them.
Read also this online user's guide for your machine.
www.yboyandrei.com/MP830_Err5C10
Please rate me if i am helpful to you.
SOURCE: Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
SOURCE: How do I cancel print job. I get message access
OPen the printer program, select the jobs and select cancel.
go to the control panel to find the printer program
