Question about Dual Electronics CECT P168 Cellular Phone
Cect A88 Call Barring
Same problem here. I pulled the phone out of my pocket and call barring was activated on all incoming and outgoing calls. I tried my sim card in another phone and it worked so the card is fine. The manual said that I can reboot the phone to original settings using the pin 0000 and call barring is one of the things that returns to the original 'off' setting. It goes through the motions of resetting, but call barring is still active.
Does anyone have any other ideas on how to deactivate call barring?
Many thanks in advance,
Scott.
How to unblock barring password for nokia 5310
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jul 18, 2011 | Nokia Cell Phones
Call barring password for Nokia 2730
Hi,call barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Samsung b7320 omniapro call barring password
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Jul 11, 2011 | Samsung Omnia Pro B7320 Smartphone
What is the barring code for Nokia n70?
The @ represents pressing the "Send" key on your mobile
##002#@ all call diverts off
*#06# IMEI Number showing
**004*DestNo#@ set all conditioned call diverts to DestNo on and active
##004#@ all conditioned call diverts (busy, not reachable, no answer) off
**21*DestNo#@ Automatic divert all calls to DestNo on and active
*21#@ Automatic divert all call DestNo activate
##21#@ Automatic divert all calls to DestNo off and inactive
#21#@ Automatic divert all calls to DestNo deactivate
*#21#@ Automatic divert all calls to DestNo status
**61*DestNo#@ Call divert when not answered on and active
*61#@ Call divert activate
##61#@ Call divert when not answered off and inactive
#61#@ Call divert deactivate
*#61#@ Call divert when not answered status
**62*DestNo#@ Call divert if not reachable on and active
*62#@ Call divert activate
##62#@ Call divert if not reachable off and inactive
#62#@ Call divert deactivate
*#62#@ Call divert if not reachable status
**67*DestNo#@ Call divert when busy on and activate
*67#@ Call divert activate
##67#@ Call divert when busy off and inactive
#67# Call divert deactivate
*#67#@ Call divert when busy status
**03*330*oldPW*newPW*newPW#@ Changing the password for call barring
**33*PW#@ Barring all outgoing calls on (PW one row before)
#33*PW#@ Barring all outgoing calls off
*#33#@ Barring all outgoing calls status
**330*PW#@ Barring all calls on
#330*PW#@ Barring all calls off
*#330*PW#@ Barring all calls status
**331*PW#@ Barring all outgoing international calls on
#331*PW#@ Barring all outgoing international calls off
*#331#@ Barring all outgoing international calls status
**332*PW#@ Barring all outgoing international calls except homecountry on
#332*PW#@ Barring all outgoing international calls except homecountry off
*#332#@ Barring all outgoing international calls except homecountry status
**333*PW#@ Barring all outgoing calls on (PW one row before)
#333*PW#@ Barring all outgoing calls off
*#333#@ Barring all outgoing calls status
**35*PW#@ Barring all incoming calls on
#35*PW#@ Barring all incoming calls off
*#35#@ Barring all incoming calls status
**351*PW#@ Barring all incoming calls if abroad on
#351*PW#@ Barring all incoming calls if abroad off
*#351#@ Barring all incoming calls if abroad status
**353*PW#@ Barring all incoming calls on
#353*PW#@ Barring all incoming calls off
*#353#@ Barring all incoming calls status
*43*#@ Call waiting on
#43##@ Call waiting off
*#43#@ Call waiting status
**61*DestNo**Seconds before divert#@ Divert call if not answered for 'seconds' (Note: Seconds must be 5, 10, 15, 20, 25, 30)
#30#DestNo@ No presentation of the number of the incoming call (CLIP)
*30#DestNo@ Presentation of the number of the incoming call (CLIP)
*#30#@ CLIP status
#31#DestNo@ Your number will not be send for the actual call (CLIR)
*31#DestNo@ Your number will be send for the actual call (CLIR)
*#31#@ CLIR status
*76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) on
#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) off
*#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) status
*77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) on
#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) off
*#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) status
Jun 10, 2011 | Nokia N70 Cellular Phone
To remove call barring activation
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
May 28, 2011 | Nokia Handsfree For 6020, 6101, 6102...
I don't know what is the password of call barring belongs my cell phone SGH-L760
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Cell Phones
I have a nokia 2730c, my number is currently barred, do you know what the code for cancelling the barring? Thank You
hi,
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
Apr 13, 2011 | Nokia 2730 Cell Phone
I want to knw hw i cn use my nokia 2700c security setting like wt is barring code and pin codes (and plz gives this two default codes )
PIN code is for simcard security the default is 12345...But if what you say is Locked code ,its the security of phone the default is 12345 ...about Barring code ,here is some tips...
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
Apr 13, 2011 | Nokia Classic 2700 Cell Phone
DONT EVER BUY CECT A88 IPHONE!! hi, can anyone help me to to deactivate all of my call barring. i bought a cect a88 few months ago. i've had this problem twice now, i cant make a call out nor receive any...
It's possible if you are on a limited call monthly contract thatwhen you run out of call time it bars your calls and when your contract renews every month you have call time so the barring lifts. If this is the case then it is nothing to do with the phone. call your network and see if you can add an option to make extra calls that are added to your bill.
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
131 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
