Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
My laptop is going on sleeping mode.
I cant able to start my laptop. It is not starting. When I am pressing main button to start the laptop is not showing any starting signal.
  • Arish Shareef
    Arish Shareef May 11, 2010
    Could you send me more details like how old your laptop is, what os i loaded in it? Is this problem all of a sudden or you haven't been using it since some time.
  • 555 Answers
Hello try to check the power setting of your laptop.
If your using Windows systems kindly follow below:
1. Goto Display Properties by right clicking the blank screen of your main
menu. Then click Property.
2. Then when Dispaly Property is pop up go to tab Screen Saver then Click
Power Button below.
3. Within the Power Option Properties kindly check the configuration of
the following:
a. Power Schemes
b. Alarms
c. Power Meter
d. Advance
reconfigure all of the tabs above and change its configuration in your own custom setting.
Need more assistance please reply to this post.
Thank you.
Posted on Jul 29, 2009
I have a pavilion dv6 - where is the sleep button
Click on the start button, choose sleep. To wake up, press the space bar or return key. That will work if you have the main board software installed otherwise press and hold the start button .
Jan 02, 2017 | Pavilion Computers & Internet
What is correct way to start computer back up from sleep mode
Unless you have set up differently, press the power button for no more than 1 second.
Mar 18, 2014 | Dell Computers & Internet
Stuck on sleep mode
Unplug the AC adapter, detach the main battery, press the power button for 15 seconds. Attach the main battery, and restart the laptop.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
HP DC7800 doesn't wake up
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity The computer will power-down and turn off unnecessary systems, including the monitor, while keeping the memory active so it can start back up quickly and still have all programs up that were being used prior to entering sleep mode. While this is a helpful feature that can extend the battery life of a laptop, it can result in errors where the computer won't power back up. You can usually solve the problem quickly.
Look for a sleep-specific key on the keyboard. It will usually be near the top row and have a symbol of a moon on it. Press this key as some laptops only respond to that command to come out of sleep mode. Press the "Enter" key to see if that will cause the computer to respond. Move the mouse back and forth several times and click the mouse button. Hold down the power button for 5 seconds if the previous methods have not worked. This is another common method for exiting sleep mode for many laptops. It may also trigger a full computer restart which would also solve the sleep mode problem. Unplug the laptop and remove its battery.
Reinsert the battery and then plug the laptop back in.
This should cause a full restart when the power button is pressed. Download the latest video drivers from the website for your video card manufacturer. Old drivers can sometimes cause problems with the laptop's power functions. See if your computer manufacturer has an updated BIOS on its website. The BIOS (basic input/output system) is the firmware that controls the initial boot processes for your laptop. Computer companies will release updated BIOS firmware if they get multiple complaints of boot or power problems. The BIOS interfering with Windows Power Manager is a frequent cause of sleep mode problems. Adjust your BIOS settings by rebooting the computer and pressing the appropriate function key when prompted on start up. It will normally be F1, F2 or F3, and you will often see a message during start up saying to press that key to enter the BIOS. Experiment with the BIOS settings by scrolling through the menu and locating Power Management. Increase the amount of time the BIOS allows before hibernating to make sure it is higher than the the Windows power setting. This can help eliminate conflicts between the BIOS and Windows concerning power shutdowns.
Jan 28, 2013 | Computers & Internet
Asus k50 will not start
If the light on the pc, not the power supply is orange this usually means the pc is not comming out of sleep mode. Try the obvious and restart it. If that does not work, attempt starting in safe mode and go to your control panel and turn off all power saving, screen saver, and sleep mode options.
Sep 24, 2012 | ASUS K50 Series K50IJ-G1B NoteBook Intel...
How do I disable sleep mode on my IBM R52 laptop?
This will probably be in the BIOS, when your pc first starts, press the delete button, this will take you to the bios, have a look around till you find it, to go out of a page press escape, when you have turned sleep mode off press F10 to save and exit.
Or when you turn your PC off , select shut down, not sleep, thats easier :)
Jul 09, 2012 | HP Pavilion dv6000z Notebook
I have an EVESHAM MS-17188B Laptop. Stuck in sleep mode! The Problem is when ever I turn it on, the power and sleep mode light is active. But nothing else, the screen stays blank, and cant hear any fans...
First advice would have been to remove battery, but since you did that, I'd say that your laptop is stuck in hybrid-sleep, or the old hibernate. Try pressing the power button for 10-15 seconds, the laptop should go off, then try presing the power button again, for normal boot.
May 05, 2011 | Computers & Internet
I can not start laptop because it stays in sleep mode.
Do A "Cold" Boot...
Remove The Battery For 30 minutes, And Leave It Unplugged..
With No Battery in and No Charger Cord Plugged In Now, Press and Hold the Power Button Down For 30 Seconds.....
After 30 minutes, Replace Battery and AC Adapter and Attemt to power on "hopefully not in sleep mode"
Nov 20, 2008 | IBM ThinkPad R31 2656 Notebook
Sony laptop
You probably have the "go to sleep" timeout set too low. Check out "Power Options" in the control panel.
Mar 05, 2008 | Computers & Internet
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
97 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
