Question about Sony DRU 500A DVD±RW Burner
DvD is not reading content off disks
DvD burner is showing as it works I put in a disk and nothing is showing for contents off disks.
  • wimsrj Jul 30, 2009
    Well I have a disk check program that I got from the SONY website, and it checks out fine for burning/writing on a disk but as soon as it trys to verify or any reading at all to a disk it does nothing, and shows nothing.
  • tommya300
    tommya300 May 11, 2010
    is the disk spinning?
  • 724 Answers
So if I understand this correctly the software says it burns ok but still dose not read.?
Can you burn withour verify and test the read in another machine.
If it the software says it burns ok than you should be able to read it any where else that is compatable
Posted on Jul 30, 2009
Dvd burner not burning
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Mar 28, 2009 | EZ Dupe EZD880 DVD RW Burner
Nec burner
Hi
First check with other disk. Again u got the problem means check whether ur driver is reading the CD/DVD.If its read and nothing is showing their is a problem in ur lens..
If u have warranty means u can claim it or else u want to change the lens..
Sep 16, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Cd-writter problem
first u buy a new lens cleaner for ur pc and run it on ur cd drive den ry to burn a new disk and see it burn or not if same prolem again comes then it is sure dat ur lense sensitivity gets low....
now it is not capable of writing ny thing only capable od read various cds......
if r havin more problems wid ur writer ask me for more solution..
Jun 19, 2008 | LG GSA-4160BI (GSA4160BK) DVD±RW Dual...
Insert a disk
How many CDROm drive installed on your PC? The message appear when you burn a CD or just only reading the content?
Mar 02, 2008 | Samsung SM 352 CD-RW/DVD-ROM Burner
HL-DT-ST DVD-RAM GSA-H54N 18 X DVD BURNER
What do you mean by not reading the disk?
When inserting a disk to the DVD drive, it runs an autorun program if one exists on the disk. By nature autorun will not run again if the disk stays in the drive. If you want to run the content of the disk, you have to execute autorun.exe from Windows Explorer. Let me know if that doesn't answer your question
Dec 28, 2007 | Computers & Internet
Contents not shown blank.....
CDROM CAN NOT READ CD'S Try cleaning the lens using a high grade CD Lens Cleaner.
Sep 16, 2007 | Sony (DRU720A) DVD±RW Dual Layer...
Plz help!!!
It sounds to me like it is one of two things. More likely that you are using a very low quality DVD. Yes there is a difference in the media that you put in and too cheap is just that, cheap. Not all the dyes that are put into a disk are equal. You can try to buy better name brand disc and try that as well. The other possibility is the that you are not finalizing the disc once it's been burned. I've noticed that on Nero the defaults tend to favor multi-session discs and use "write at once" instead of "disc at once." So try using the disc at once feature or finalizing the disc to see if that helps. I know that some legacy drives have a hard time with multi-session discs still. I hope that helps. I know my Sony drives works great and I've been very happy with it.
Jun 19, 2007 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Sony DRU 500A DVD±RW Burner Logo
178 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
