Question about Kenmore 82722 Electric Portable Dryer
Dryer makes noise and smells like it is burning
    Brigadier General:
  • 3,513 Answers
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Thank you for contacting www.Fixya.com
Posted on Jul 29, 2009
    Habit-Forming:
  • 74 Answers
Check the idler. Sounds like it froze up?
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Burning smell but not odd sounds
make sure vent is cleared MDG is a gas dryer so sometimes when theyre heating it may smell different than youre used to. blower impeller wheel has a "D" shaped hole & can round out causing it to hang up the motor which could cause a burning smell but usually will make a lot of noise B4 that will happen.
Jun 29, 2012 | Maytag Neptune MDG5500AW Gas Dryer
My dryer is making noise, vibrating and smells like it is burning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fg
Jul 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
Crosley CDE8000W Dryer has electric burning smell and shut down
it is most likely the belt. the squealing noise is because the motor is turning, but the belt is not. a replacement belt is not too expensive and it is fairly easy to replace. if you need directions how to replace it, let me know
Oct 27, 2008 | Dryers
Kenmore 82722 Electric Portable Dryer Logo
256 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
