Question about Acer Aspire One PC Notebook
My battery is not gettiing charged on aspire zg5 model, i am looking for drivers for "microsoft acpi compliant control method battery ". could not find a place to down load.... wanna replace the old drivers and see if it going to work
  • Buuunge
    Buuunge May 11, 2010
    Could you please explain more about the problem and what makes you think that you need to update this driver? Is there a hardware conflict in device manager?
Packard bell accu batterij dot 8.9 inch dot zg5
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4.Click Scan for hardware changes on the Device Manager taskbar.
Please let me know if you still have your problem,and thanks for using fixya
Aug 30, 2012 | HP Computers & Internet
Charge light on but no power
If the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
On the Device Manager taskbar, click Scan for hardware changes
Please let me know if it's working
Aug 26, 2012 | HP Computers & Internet
Toshiba c650 repair manual
4. On the Device Manager taskbar, click Scan for hardware changes .
Aug 26, 2012 | Toshiba Computers & Internet
I have got a acer aspire 5750z but nearly every time i try to charge it the charger needs me to take the fuse out and in untill it workes
If the notebook battery is not charging or the notebook does not indicate that the battery is charging, it's looks like that the battery is working, but its power management software may have a problem. You will need to uninstall and reinstall the power management software by using the Device Manager.
1.go to device manager
Right click on my computer->select Properties->click the Hardware tab->click device manager
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
Aug 25, 2012 | Acer Aspire 5720 6497 Laptop
Battery plugged in but not charging
Aug 25, 2012 | Lenovo Computers & Internet
Battery not charging in lenovo y410 laptop
Aug 03, 2012 | Lenovo 3000 Y410 Laptop
Battery not charging on aspire 5736z
  1. Install the BIOS. (from acer website)
  2. Reboot, log back on, delete the "Microsoft ACPI-Compliant Control Method Battery"
  3. Shut down.
  4. Removed the battery, unplug the power, waited a few minutes, tapped on the keyboard with voodoo chicken feet.
  5. Plugged it back in without the battery, booted it
  6. Logged on, deleted the ACPI driver again.
  7. Plugged the battery back in (hot, not shut down)
  8. Rescanned for hardware changes.
Mar 22, 2012 | Acer Computers & Internet
Touchpad and keyboard no respond
The problem for the Acer Aspire 3000 series is into the chipset battery, that comunicate to the PC through a serial protocol (probably I2C) to sent information, charge, status, etc.
Due to an ACPI bug, the battery module is not recognized by Windows. Bios upgrade doesn't solve the problem.
To solve the proble there are three ways:
- change the Hal driver to "PC standard"
- disable (not uninstall) the "Microsoft ACPI-Compliant Control Method Battery " and "Microsoft AC adapter"
- unplug the battery for 1 minute and re-plug it (with windows running).
The first metod work fine but Wi-Fi doesn't wok. All the rest of hardware yes, "Suspend" not possible, you must torn off the PC manally. Not Good!
The second is the right. It work only if your PC (HAL driver) is configured at "PC uniprocessor ACPI", see Microsoft documentation for help (HAL options after Windows Xp setup...).
The best way is to install a fresh Windows Xp, WITHOUT BATTERY INSERTED!!!. Windows configure it automatically in the right option.
After installion start Windows, important leave battery unplug,
then go to the device manager, expand "Batteries"; than disable "Microsoft ACPI-Compliant Control Method Battery" and "Microsoft AC adapter". It's fondamental to not disinstall them, otherwise windows re-install them at next boot!
Now you have a complete usable PC with ACPI enable (suspend, auto power off,...), windows does not comunicate with the battery, and the system doesn't freeze. The PC is also able to charge the battery and use it, the only unusable function is the battery status.
The battery infact is charged by hardware not by software. If you are in battery mode you can't now how charge remain.
I have an Acer Aspire 3005 WLMi, with the same bug and now i use it without problem.
Sorry for my bad english,
Stefano Bassi.
Dec 26, 2010 | Acer Aspire 3000 Notebook
I have a hp pavilion dv6500 notebook pc which is having problems holding a charge. I recently replaced the power adapter with a 65 Watt power adapter and same problem. Not sure the wattage of the original...
start with removing the Microsoft ACPI Compliant Control Method Battery from device manager. Right click my computer > manage > device manager. right click unistall the Microsoft ACPI Compliant Control Method Battery.
If that doesn't work look for a BIOS update on the HP website. Known issue with this series.
Mar 12, 2010 | HP Computers & Internet
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
227 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
