SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: Samsung Galaxy keeps asking me
you can try fake email id and password to enter.and other option is to create new Gmail account,it's take less than 5 minuts to create.
SOURCE: how to reset samsung galaxy 551
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: Unable to unlock my Samsung Galaxy GT S 5570
if it is says too many pattern attempt ,your phone need to reset ...do this tricks ,...
1. Power off phone
2. Press and hold Menu Button ( middle ) + power on for at least 10 seconds
3. Android System Recovery Mode Appear
4. There are 4 options
5. Move the options to " Wipe data / factory reset " using volume down (
- ) button and menu button to confirm, because the touchscreen doesn't
work in reovery modereboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
6. After the process done, phone will reboot.
Sounds too simple and maybe you have tried it but pull out the battery and see if that resets. I have a blackberry and it worked for me.
