Question about Sanyo SR-4912M
Keeps freezing over. It's only set to minimum cold. Is it the motor? What do I need to replace?
  • asleff Jul 29, 2009
    Any ideas where I order this part from? Partstore.com?
    Thanks again. asleff@verizon.net
    President:
  • 2,559 Answers
The defrost timer
Posted on Jul 29, 2009
  • Dean Hamilton Nov 06, 2011
    where do you find a defrost timer for this model???
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
Appliances -refridgerator lower unit much to cold.
What is the model number of your unit?
Nov 23, 2012 | Refrigerators
Refrigerator keeps getting colder and colder. I reset the temp every time I open it, but it goes back to being too cold. Is registering 24! GE Profile side by side with ice and water through the door.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the plastic air deflector at the top rear of the refrigerator, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Hoping that this will help to solve the problem...
Sep 09, 2011 | Refrigerators
I have a Kenmore Trio 76504 that the refrigerator keeps freezing products on the back of any shelf or crisper bin
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem....
May 15, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kitchen Aid will refrigerator motor keeps running. Things are cold but the motor sense like it is always running.
If it is not freezing up or set too cold, you may be losing coldness somewhere. Are the seals all in good order? Do you open it very often and leave the door open? Do you put hot stuff in the fridge? All these things would contribute to that problem.
Sep 06, 2010 | KitchenAid KSRS25FG
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Fridge keeps freezing up
Then replace the thermostat. It's cheaper that wasting all that beer. Seriously I think your thermostat is broken and stuck on coldest setting. Sea Breeze
Aug 21, 2009 | Kenmore 564-91179400 / 564-911714001
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Sanyo SR-4912M Logo
246 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
