In my mobile home I have a coleman furnace model number 7970-856. It was over 100 degrees today and my furnace fan is stuck running and I don't now if it's supposed to do day. There is no fan switch on the wall thermostat and I am not sure if the fan is stuck on.
    Habit-Forming:
  • 74 Answers
There is a fan cycle switch that turns on the fan when the unit heats up (so it won't be blowing cold air) and runs the fan after the unit has shut off to remove heat from the unit. Sounds like it bit the dust. It is located next to the firebox.
Posted on Jul 29, 2009
No a miller furnace I was told a nozzle was for homes and b was for mobile homes furnace. I have a miller furnace I want to put what is the right one in can you help me
Did you have an old nozzle to look at? The one that you're replacing? The Miller gun furnace for mobile homes is probably a .75 gal/hr. nozzle or less. You need a furnace tech to look at your furnace if you can't read the info. stamped on the nozzle. It will have a .75, or .65 maybe gal/hr rating and a number for the angle in degrees.Like 80 degree nozzle.
If you match up what came out of it,you should be fine. don-ohio (:^)
Dec 27, 2016 | Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Furnace fan will not shut off
if the fan just runs check the limits there is about three of them and a high limit some of them are Manuel rest witch means you have to press the button on them
Dec 25, 2012 | Coleman Mobile Modular Home Gas Furnace...
Coleman furnace
Is this a blend air system? If so, there is an upper & lower control board that communicate to each other, and if the exhaust fan on the roof is out, it will give you intermittent issues. The fan mixes or blends outside air with the return of the air handler, & duals to pressurize the attic. These were installed due to mobile homes built too air tight. Without this fan, your roofing shingles will curl, and your roof decking will bow prematurely.
Dec 22, 2012 | Coleman Mobile Modular Home Gas Furnace...
Gas furnace for mobile home, Coleman DGAM056BDD, attic fan runs continuously.
Is your thermostat set to on?That would make it run continuously.There is a relay in the Coleman unit that could be stuck. Good luck--
Sep 09, 2009 | Heating & Cooling
I have a 1971 mobile home and it has a coleman gas furnace in it modle #8665D766. I can turn the thermastate up and the combustion fan comes right on but the igniter never ignites. The pilot lite is lit....
It sounds as if one of the sensors is not signaling correctly, If the combustion fan is on. What you need to due is turn things off for a minute to test your sensors. Start by looking at the emission sensors. This can be done by looking at the schematic and following the line of electrical flow to the main switch. I had this same problem on a home furnace and all I did was follow that line of flow and checked the sensors by disconnecting each to see which one showed either an open or closed circuit, when it was supposed to be just the opposite. (Usually its supposed to be open if no flame is present, so you might see a short) It was in fact the sensor in combo to the igniter fan. If you don’t have the schematic I would look to Colman. All these circuits are simple circuits and very little trouble shooting to resolve. The hardest part is finding the parts to fix it. Thus the internet and the need for a schematic if you can find one. Most heating and air-conditioning outlets wont sell you parts even if you have an engineering degree and don’t want do deal with a technicians BILL.
May 10, 2009 | Coleman Heating & Cooling
Coleman mobile home electric furnace
Peace,
It seems you need hands on servicethis time !
ngafm
Bless You,
Please leave me a rating before you sign off!
Thank You
Sep 07, 2008 | Heating & Cooling
Heating & Cooling Logo
253 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
