Question about HP Designjet T610 InkJet Printer
Paper load incorecctly
I used this ploter without any problem but today i wanted to put another paper roll but i get this error message paper load incorecctly everythhing is allright and the same as before.
    Sergeant:
    Champion:
  • 283 Answers
Reinstall the driver of your printer. if doest work then check the roller. tnx
Posted on Jul 29, 2009
Lift blue error
Typically the lift blue lever error comes up if the plotter detects skew when loading paper. If the paper cannot be loaded without skew then either you do not have the roll seated on the holder properly or the roll of paper was not made properly, which I have seen.
Feb 16, 2016 | HP DesignJet 500ps (42 in.) InkJet Printer
Remove paper from sheet feed when no paper loaded
It is possible that the genuine replacement HP sensor is defective.
Jan 09, 2014 | HP DESIGNJET T770 Printer
Message saying out of paper, however it has a full roll
The only plotter I have any experience with has a "Load/Eject" button. This button must be pressed once before attempting to load the end of the roll into the machine, otherwise the machine will not attempt to pick up the roll. If your machine has any similar functionality, it may just be that simple. Push button, load end of paper roll into pick-up slot.
As for the driver, you'll have to select you operating system from the list here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=12607&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=24023
After downloading and installing the appropriate driver for your operating system, if it still doesn't work, be sure to record any error messages you get. Sometimes, the error messages can help point to a solution when searched for on the internet. Without specifics, I can't recommend anything.
Sometimes, it happens that a specific system has had many different printers installed and uninstalled over the years, and some drivers can cause the print spooler in an operating system to malfunction. If you can, try reinstalling your operating system, and then installing the print driver. Remember to back up any important files, pictures, and documents before you reinstall. Usually a reinstall will format your hard drive, and all that information would be deleted by default.
Mar 15, 2013 | HP DesignJet 1050c plus InkJet Printer
Print jobs print as portrait and not landscape
you need to change the print settings in the program where you are printing, when you go to print settings the option should be in the dialog box where you choose the printer and page amount.
Mar 02, 2011 | HP Designjet Z6100 InkJet Printer
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error message
Make sure you have put the printer roll core in ! Don't lose that core cause you must have it for the printer to see the paper.
Mar 22, 2009 | Sony SnapLab UP-CR10L Digital Photo...
Error Code E0200D
I think making sure the paper is properly aligned fixes that problem. I get it once in awhile.
Feb 19, 2008 | Canon imagePROGRAF W6400 InkJet Printer
HP Designjet T610 InkJet Printer Logo
318 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
