Question about Compaq Presario 5000 PC Desktop
Cant take the front panel of 5sw398 - Compaq Presario 5000 PC Desktop
    Scholar:
  • 97 Answers
Try opening the case up on both sides and looking towards the front. A lot of times there are either screws that you need to remove at the top and bottom of each side, or plastic clips that you need to push in. Hope this helps.
Posted on Jul 29, 2009
    Problem Solver:
  • 4 Answers
You can but have to unscrew from within case, Although be careful dont want to break anything.
Remove front panel
It has an interlocking system. Try using a screw drive on side with a little pressure.
Mar 05, 2014 | Hotpoint Washing Machines
Cant get front panel off washer to check mcu unit as suggested.
There should be 3 t20 tork screws at bottom of kick panel. You could also take the whole back panel off to get to the motor control unit, it is located in the back lower rh corner.
Jan 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Need to replace orfices cant figure out how to get cover off to get to valve
You don't give model #. Most Maytags have 2 screws at bottom of front panel. Remove and swing panel forward from the bottom. Some Maytags require removing the front panel (2 or 4 screws around the door opening). Slide and pull front panel off.
Oct 23, 2013 | Maytag Dryers
Cant get the front panel off
Just gonna have to put some muscle into it to release the tabs. Just be a little careful, you wont hurt it.
Nov 28, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I cant listen to the sound in front panel
Probably as simple as the front panel is not connected.
Be sure the front panel cables are connected to the correct audio output connector/pins on the MB.
http://www.asrock.com/support/index.asp and get the manual
for the board so you know where and how they should be connected.
Jul 12, 2010 | Asrock G31M-S Motherboard
Cant change channels or input using front panel/no remote
Buy a new remote,tries this website for an exact remote or very closse to the original.1-800-Factory Original.
Sep 30, 2009 | Emerson CR202EM9 TV
How do I free the lower part of the front panel?
After wrestling with the front panel for awhile it finally came off. On the inside of the sides of the lower front panel are plastic extenders which fit into the groove openings on the lower part on the side of the metal housing. Thus the key is to pull from the side of the lower front panel away from the housing.
May 15, 2009 | Maytag M6Q10F2A Air Conditioner
My panasonic project tv colors are crazy cant fix convergence lin
you must adjust it by hand located in the front of the tv you must remove front panel and speaker panel,s you will se six
Jan 17, 2009 | Panasonic PT-51G44 51" Rear Projection...
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Front panel locked out cant turn on tv
use the remote go into the menu and unlock the front panel,
there is a combo of buttons to unlock the front panel but you will have to see the manual.
May 06, 2008 | Televison & Video
Compaq Presario 5000 PC Desktop Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
