The shower is active throughout October, but Kerss reckons the best time to see it will be on October 22 between midnight and dawn, when the sky is darkest and the shower will be at its brightest.
"We expect the peak to occur on the night of 21/22 October (Saturday night and Sunday morning) when the young crescent Moon will set conveniently before the radiant of the shower - the point from which the meteors appear to spread out - rises in the East," said Kerss.
"Make a plan to stay out between midnight and 3am on Sunday morning to give yourself the best chance, and enjoy the thrill of seeing tiny flecks of Halley's Comet disintegrate at hypersonic speeds (safely) above your head."
Everything you need to know about the Orionid meteor shower
SOURCE: I have the i9++ and my network provider is meteor
Chinamanuals.com can help you.They have i9 Sciphone settings for each provider worldwide. Sendthem a request with your providers name and your country.
SOURCE: what do we need to get my boyfriend too+settled in ireland??
you will need to contact Ireland Embassy to know about the rule and regulations for a non-ireland citizen to become one once you get married.
SOURCE: i live rep of ireland but when i travel to
Hello,the truth is that you can unlock the phone ,but you can't unlock all phone for free.The payment sites are very cheap you could try it out and see.You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can get a free unlock code.
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/tag/cell+phone+unlocking/hot)
and
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
SOURCE: WE HAVE A KUPPERBUSCH MICROWAVE
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html Also remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Somtimes the wave guides with food particles can burn and smoke if so replace the wave guide.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
SOURCE: unlock lumia 800 on meteor
Hi visit Theunlockarena.com to unlock your Nokia lumia 800 from Metro network .Here they ask you the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
