Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
How to adjust LCD wide monitor to a higher
Recently bought an Acer 15 inch LCD monitor to replace old CRT monitor. I can't adjust the resolution higher than 800x500. Thank you.
  • EliteGroup Master
  • 32,281 Answers
This error is typical of an incorrect video driver has been installed.
To check the installed video driver go to Control Panel - Display - Settings tab - Advance button - Adapter tab. This shows the adapter/driver. If it shows VGA graphics card or not the model of your graphics card then you need to download the correct graphic/video driver and install it. You will then able to configure the display at a higher resolution and at the highest color bit (ie 32 bit if there is sufficient video RAM installed).
Posted on Jul 29, 2009
Crt monitor height are coming very small in size picture wat probelm
Did you set ur resolution screen setting higher than 1024 in ur computer panel resosulion setting?Yes than that is ur problems right there.CRT monitors modes are based on old technologies ,CRT monitors can't go up more than 1024 resolution setting.Setting resolution more than 1024 resolution for CRT models monitors will have thesse causes.The screen resolution on the screen will shrink and get smaller or will not have video resolution on the CRT monitors screens at all.Only LCD or LED monitors models can support and go higher than 1024 resolution setting has none of these causes.Time to upgrade for a new monitors technologies like LCD or LED monitors models.
Oct 17, 2012 | Computers & Internet
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
Im useuing a lg crt 15 inc monitor, few days ago im connecting my pc with samsung lcd 22 inc monitor, but the problem is when im re connecting that crt monitor its only show out of frequency.
the resolution might be too high for the CRT monitor, try to lower the resolution if your going to connect the CRT monitor..., the 22 inc monitor obviously have much higher resolution that the 15" crt monitor. i think the max for that is 1024x800.. hope this helps :)
May 10, 2011 | Computers & Internet
I have a wide screen Acer monitor, yet am unable to view my whole web site without scrolling down. I have adjusted the resolution to allow the font to fit on the page, and can see it perfectly with IE,...
Sounds like either your display resolution needs to be set higher or when you bring up firefox after the page loads press and hold the ALT key and Click View, ToolBars and select Menu Bar. This will keep it at the top everytime you open firefox. Now under View you can zoom in and zoom out. You can also select Full Screen. *** Before doing anything did you click the middle box at the top right hand corner of the screen between the - and red x? This toggles between full screen also.
Feb 25, 2018 | Acer X243W 24" TFT wide format screen 24...
Acer wide screen monitor 20'' font and images all
Right click on the desktop in a clear area and scroll down to either resolution or properties. From this you can experiment with resolution settings to see which setting best fits your display. After each setting change the computer will ask you if you want to accept the changes, it will give you 15 seconds for each change.
Jun 26, 2010 | Acer AL2016W 20" LCD Monitor
Acer top and bottom of screen is blank
on the monitor press the menu button in that adjust the horizontal and vertical size correctly ... you will having the option to adjust in the menu button ...
or you may be using some low resolution check the display properties set your resolution to 1024 x 768 ...
this will fix your problem ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | Acer Computers & Internet
X2gen MV19 monitor: can only get VGA resolution
unscrew the monitor check behind the line transformer you will see two buttons for adjustment use them to increase your resolution manually
pls make sure the monitor is shut down for abt 15-30 minutes before you attempt opening it to avoid electric shock
Mar 17, 2008 | Computers & Internet
Al1917w lcd monitor resolution problem
I have the same problem! Here's what I did: Go into the Display control panel, go to SETTINGS, click on ADVANCED, and then on the ADAPTER tab, then on LIST ALL MODES. There are several 1400 settings. Try them out and see which one is best for you.
Jul 30, 2007 | Acer AL1917W LCD Monitor
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
255 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
