Question about RCA F25432 25" TV
Maatmartin7 has a CTC203AC5 MODEL# f25423. iT WILL POWER UP, THERE IS AUDIO AND YOU CAN CHANGE CHANNELS. bUT THE PROBLEM IS A LIGHT BLUE/GREEN RASTER WITH RETRACE LINES. NO PICTURE , THERE IS THE ONSCREEN DISPLAY. WHAT IS THE PROBLEM AND THE SPECIFICS TO CORRECT THE PICTURE?
  • 5 more comments
  • matt martin
    matt martin Jul 30, 2009
    I will check this. It is odd that i have on screen display and no video. I may have another question so stay tuned. Ill let you know right after this commercial break! TANX
  • matt martin
  • matt martin
    matt martin Aug 05, 2009
    Checking the crt board...one of the color amp transistors will not measure at collector and emitter. The transistor is good. Diode cr14704 reads leaky in circuit....checks out good out of circuit. Still searching.....will be sometime before i get back to you. I welcome any ideas Tanx jingjao
  • matt martin
    matt martin Aug 25, 2009
    The CRT board is good. The return voltage is not present between collector and emitter of Q15103. I still belive the FB is good...and the eeprom may be good. What are the chances U12101 is bad? What should I check before replacing the 52 pin IC?
  • matt martin
  • matt martin
    matt martin Sep 14, 2009
    I replaced IC U12101. I now have a picture and can watch tv. The next problem [same tv] I am missing one color...The picture is of yellow shade. Do you suppose I need to replace the eeprom. And does the eeprom help shoot red, blue and green to the picture tube? I did check the tube and it is good.
  • matt martin
    matt martin Sep 28, 2009
    The CRT board is good. There is no return voltage on the blue color output transistor. The color blue is missing. Where would it be?
    Champion:
  • 252 Answers
The problem of your tv is in the CRT section, try to check the RGB if they have thesame voltage.
Posted on Jul 29, 2009
Kc LT-32x575. Turns on for 3-5 seconds with video then screen goes black but still have sound volume and channels change but no raster turn off and back on does the same every time
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 14, 2015 | Televison & Video
Blue screen has audio can change channels and hear different audio but no picture
Hello
If you can see menu on-screen display, just get into it, surf for blue-back option and turn it OFF first, and see whether there is any grains appears on your screen. If there is no grains, and only a plane raster, your TVs video processor Ic has got damaged, and should need replacement. If there is grains, you just retune it in autotuning option, and allow it to store all the transmitting signals at that time. This process may take two or three minutes to complete, and you should wait till then. Never forget to connect antenna socket to the antenna terminal of your tv.
If you are using set top box, and connected it to the TV through audio-video cable, your TV has no fault, but the set top boxs' video processor has got damaged. OK,
Nov 24, 2010 | Sanyo DS31520 31" TV
Hitachi model 50v71discolorization on the screen
You have a small signal board that needs reworked. Also known as the convergence board. Send off to PTS Electronics.
Sep 15, 2009 | Hitachi 53UDX10B 53" Rear Projection...
RCA 32V434T (32'') TV has no Red or Green pixels, only Blue
The color problems are caused by cracked/broken solder joints on the circuit that controls the display.  Usually this is located at the back of the tube on a small circuit board. Your description suggests that only the blue signal circuit is intact. I suggest these joints be resoldered for more strength.
It's a possibility that another IC senses this problem (or another one) and then shuts down the system.
Resolder those joints and see what happens.
Jun 03, 2009 | Televison & Video
No picture
Possibly but I will need a great deal more informtion... When you say no pic, do you have any raster, blue screen or any light at all?? Sound - when you change channels does it appear to change or stuck on the same channel? If you look across the screen can you see an image of a picture - use a flash light in same direction - any image at all??
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 10, 2008 | NEC PlasmaSync 42MP2 42 in. Television
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423...
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Jun 15, 2008 | RCA Televison & Video
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
RCA F25432 25" TV Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
