Question about General Electric WSSH300G Front Load Washer
I accidentally pressed the select and option button together and locked the control panel. The manual says to press these two buttons again. I cannot get the control panel to unlock.
  • brad_wentzel Jul 31, 2009
    I tried disconnecting the power and this did not reset the problem. I read the manual which told me to hold down the select and option button for three seconds.
    The fix turned out that I had the hold both buttons down for around 30 seconds. This would be nice to have in the manual.
    Removing the power does not reset the control panel lock. The control board has non-volital memory.
    The manual says hold both buttons down for three seconds to remove the control panel lock.
    The fix ended up being, holding the two buttons down for much longer, around 30 seconds until I heard a beep.
    New Friend:
    Problem Solver:
  • 7 Answers
F fresh gently pushing the lock button on the front load GE washer and asking for help not gettinh any through trial and error I figured it out myself if you accidentally lock yourself out of a front load washer to clear the lock light and let you back in just press and hold start/pause button until red light goes off
Posted on Jul 12, 2015
  • 636 Answers
Disconnect the power to the unit this should reset it for you.
Posted on Jul 29, 2009
  • mike fuson Jul 31, 2009
    Sorry about the miss info , I have a kenmore front load which had done the same on me and unplugging the unit, seamed to have solved my wife's dilemma. Handy at most things, no expert at others.
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
My sharp tv was accidentally lock and i can't even remember the password again. pls what will I do?
hi,
Check the following two procedures to unlock the tv.
1. Press and hold the display button on the remote for 5 seconds for unlocking the tv.. if doesnt help then,
1. Press VOL -- button on the frond panel of the tv and Child lock button on the Remote together. (remote should be faced to tv when you press the buttons)
2. Press MODE button on the remote
3. Using channel +/-- select chid lock
4. Enter New code
5. Press the mode button
OK
Sep 19, 2011 | Televison & Video
All my chanels are blocked every time i change the chanel ive got to press the 1111 key every time to get the station
You've probably activated the parental control / child lock. This can be done accidentally by pressing a certain combination of buttons on the remote. To turn this off:
1. Press the "MENU" button on the remote control
2. Select the "LOCK" option (the padlock icon) with the left and right arrow buttons "" ">" on the remote
3. Enter the password. The default is 0000 but yours appears to be set to 1111. Try either or both.
4. On the next screem make sure "SYSTEM LOCK" and "UNRATED LOCK" are set to "OFF". Highlight each option with the up and down arrows on the remote and change the setting using "" or ">"
5. When they are both set to "OFF", press "MENU" again to return to watching TV.
All your channels should now be unblocked.
Hope this helps. If you need further assistance, please post back.
Regards,
BElectric
Dec 05, 2010 | AOC L24H898 24 in. LCD TV
What does the code LOC mean?
HI. This is a simple lockout feature that will allow you to prevent accidental starts or stops when children are present. It can be initiated by pressing the Options and Select buttons at the same time for ten seconds. This will initiate the lockout feature and the letters "LOC" will appear on your display. To remove the control lock out, simply, press the Options and Select buttons together once again at the same time and hold them for 10 seconds. This will release the lock out and the letters "LOC" will disappear.
Jul 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I'm having trouble deleting pictures any advice would be helpfull.
normal procedure for deleting images using a dscs700 cam.
1. press playback button (button you use for viewing images, located just above the lcd screen,left side w/arrow icon pointing to the left)
2.salect the image by pressing the left or right control button
3.once image to be deleted is selected, press the delete button (2 black squares w/a slash and garbage can icon,below the control buttons on the left side).
4.select delete option by pressing the up control button.
5.press middle of the control button to confirm.
...or if you would like to just remove everything on the memory stick including protected images you can just format the ms by:
1.press menu to diplay menu settings.
2.press right control button to go to setup (looks like a toolbox or suitcase icon) and press the right control button again.
3.press the down control button to go to Memory Stick Tool and press right again to confirm selection.
4.press right control button to select format.
5.press up control to select ok and press middle control button. message will appear telling you that "all data in ms will be erased.ready?"
6'press up control to select ok and confirm by pressing middle control button.format completed.
hope this info helps. thanks:)
Apr 13, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
Feb 21, 2009 | Frigidaire ATF6000ES Front Load Washer
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Kenmore front load washer 970-c45072-00
We had the same problem and this website solved it for us. The child lock is on when the lock symbol light in the lower right of the panel is on. The machine will not start with the light on. If you press the Option and Select buttons together (there is a lock symbol with a line to the two buttons), the lock symbol light will switch between on and off. When it's off, the machine can start. None of this was in the "Use and Care Guide," maybe we lost our manual. But thanks for helping to solve the problem!
Nov 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
General Electric WSSH300G Front Load Washer Logo
183 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
