Question about Maytag Electronic Portable Air Conditioner Heat
Maytag I have a maytag air conditioner m6po9d2a+b it blows cold air for at least 1 min and than hot air for at least 3 min
    Habit-Forming:
  • 74 Answers
Could be several things. Make sure evap coil is clear. Use a garden hose if you need to for the mud in the back. If both coils are (clean evap and condenser) Then it probally is short on refrigerant.
Posted on Jul 29, 2009
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Air conditioner starts out blowing cold air,apparently actuator sticks causing the system to blow very hot air. Hours later a/c blows very cold air again, only to blow wry hot air again after about 30...
1.)If your System is OVERCHARGED this Will Occure due to the EVAPERATOR FREEZING UP
2.) Also if your HVAC Control Modual is Malfunctioning this will Aslo Cause this Condition, It Controls the BLEND DOORS that OPEN for COLD or HOT AIR Look Into these Items and Also Look Into wethrt the A/C Compressor Cycles OFF when it GETS OFF this Will POINT at the HVAC CONTROLER if it Cycles Off When Set For A/C or COLD Air
Aug 19, 2010 | Chevrolet C1500 Cars & Trucks
MAKES A LOUD NOISE AND BLOW HOT AIR AFTER BEING ON FOR A 5MIN
You can try to turn the power off and then on again at the disconnect for the outdoor unit...
However the problem is likely more complicated then that...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 25, 2010 | Ruud UBHC Air Conditioner
Not blowing cold air, do u recharge this unit?
only after you find a leak. first u have to make sure if the compressor is running at all. condenser side spinning. if compressor is not working it will blow hot air if the condenser is dirty or blocked but then u would get a minute or two of cold air then hot. you have to determine its empty or what else might be the cause before you start dumping in freon.
May 25, 2009 | Samsung Heating & Cooling
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Jul 03, 2008 | Maytag Portable Air Conditioner M6P09S2A
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Mar 26, 2008 | Hunter 30124 Air Conditioner
Maytag Electronic Portable Air Conditioner Heat Logo
293 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
