Question about Palm Z22 Handheld
The touch screen doesnt respond - Palm Z22 Handheld
  • Palm Master
  • 13,433 Answers
Have you tried a reset? How about a hard reset?
To do a normal reset, press on the reset button on your handheld.
Hard reset is performed differently on different models, check palm website for hard reset instructions: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj%28887%29
if the touchscreen doesn't work at all, and you can't align or calibrate it, or it presses on wrong spots even after calibrating many times, the digitizer (which is the touch part on top of the lcd display) is most likely broken and would need to be replaced. On rare cases reattaching the digitizer cable and making sure that the digitizer is clean may solve the issue.
If you are inside warranty the repair may be completely free, contact your dealer or palm.
Outside of warranty, you have 3 options.
1. Replace the digitizer yourself, you can find a replacement from ebay for pretty cheap.
2. Send it to palm for out of warranty repairs, probably around 100usd.
3. Take it to a local professional who can replace the digitizer for you.
Thanks, let me know if you have any questions and good luck.
Ekse
Posted on Jul 29, 2009
    Problem Solver:
  • 16 Answers
I had the same problem and tried several of the solutions here, from cleaning around the edges of the screen, to soft and hard resets. They worked for a time, but eventually, the pointer didn't register at all. Before you throw out your unit, look on Ebay for the replacement digitizer. There are or were many when I looked, ranging from about $8 to considerably more. None of the low cost ones came with instructions, but did come with tools. Higher priced offerings were for having them replace the digitizer for you. I ordered the low priced one and figured I could figure it out. The tools they send are two tiny screw drivers with special tips and a small plastic device to pry the sections apart. If you want to do it yourself, I will be happy to explain what I did. Remember to be really gentle when you do every step. First use the pry tool on the place where the cord plugs in to connect the device to the usb slot on your computer. It is tight, but gently pry out the small black rectangle. You will see two tiny screws inside. Remove those, carefully with one of the screwdrivers that come with the digitizer and set them someplace save. These two screws or bolts have nuts, that you can't really see until the next step. Watch for them if they fall out. The next step is to use the pry tool around the edges of the white plastic face of the Z22 and separate it from the back. I would lay it on the back while you do this. There is a small u-shaped piece that is part of the reset button and it fits on a peg on the back part of the device. Carefully ease the front and back apart. There are 4 small screws that still need to be removed. Save them to replace when done. Remove the innards of the device, but Don't totally separate the sections. There are foil connectors that attach the parts and they need to be intact. Gently ease the digitizer from the white plastic face. It will have another white plastic box on it's back side. Use the pry device to separate the glass digitizer from that white box. You will see there is a gold striped foil connector on your new digitizer, about midway up the side of the device. Find the one that is connected to the old digitizer and ease it out of the slot. Remove the old digitizer. Slide the new connector into the slot. Position the new glass digitizer correctly over the white plastic box and place the innards face down into the white face of the Z22. Replace the 4 screws. Gently close the case, laying the front onto the back, so you don't displace the reset button part. Snap together and replace the two tiny screws into the section near the power cord connector. (Hopefully you didn't drop the little nuts out, during the process. If you did, you may have to back track until you can see the small white boxes that they slip into, in that location. Email me if you have problems with this. It sounds a lot worse than it was. When I finished, I was really disappointed, because it didn't turn on, the whole screen was black, which was worse than when I started. But, after I plugged it in, and let it charge about 3 hours, it worked perfectly! I am so excited! You can do this if you are patient and gentle. <!-- from fixya rte -->
Posted on Aug 17, 2010
Pfaff creative 7570 touch screen doesnt work
it's possible that the computer has gone out, since it's used it would be a good idea to have it checked.
Mar 08, 2014 | Sewing Machines
My touch screen wont respond to touch or stylus or anything at all...screen looks great it just doesnt respond
Can you please advise which model, and what is the problem you have....good detail works best for a better, faster reply..Please use this link ... Contact Us at Bargain Box
Huawei m866 touch screen stuck on android touch doesnt work
MOBILE PHONE TYPE> HAUWEI M886 ANDROID SMART PHONE
SITUATION > TOUCH SCREEN NOT RESPONDING I CANNOT PROVIDE MAINTENANCE TO MOBLE PHONE... IT TURNS ON BUT CANNOT MAKE SELECTIONS
Jan 22, 2013 | Huawei M886 Mercury - 4GB - Black Cricket...
My touch screen doesnt respond properly. What could be the probable issue?
tap start>setting>system>screen>align screen, the calibration starts tap on center of +
May 20, 2010 | HTC Touch P3450 Smartphone
Touch screen on lg vue will not respond at all!!!
your touch sensors have gone out. If there is any on off touch screen faulty's to where u can click once every while.try to get to touch calibration. If u do and it doesnt out, read the first sentence over.
Apr 29, 2010 | LG Vu CU920 Cellular Phone
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Lg cookie touch screen not responding. i can turn it on perfectly and all the buttons work but the touch screen just doesnt.
my lg cookie toucch screen not responding , i can turn it on perfectly and all the buttons work but the touch screen just doesnt.
Dec 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Palm Z22 Handheld Logo
723 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
