Question about Sony Playstation 3 (PS3) Console
I have all the numers and everything in the rigt spots 2 hook up 2 the wirless router but it keepssaying error code 8001000A.... Do u know what the problem is?
    President:
  • 2,559 Answers
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
Confirm that an Ethernet cable is not connected to the PS3™ system.
Select (Network Settings) under (Settings) in the home menu.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
Select [Easy].
Select [Wireless].
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
Check the SSID for the access point.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
Save your settings.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Hints If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Posted on Jul 29, 2009
    Sniper:
  • 89 Answers
It sounds like the router is blocking your ps3 mac adress try theses steps
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. you do this with a computer already connect with your router This is usually done my typing the router's IP address on your browser. ie http://192.168.1.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic hope this helps
Error 8001000A IN MY PS3
hi,
you don't need to connect the router to ps3 configure it one one pc/laptop then activate the wireless on the router,then setup the wireless connection on ps3.
Apr 07, 2014 | Zyxel Computers & Internet
My playstation 3 has bee connected to the internet for 5days and when i went to log on to psn today it came up with error code 8001000a andwill not detect any network ports im stuck on what to do
unplug your modem and router clear networking settings on your ps3 connect all cables if aplicable swich on modem and router set up network setings. you could try turning off the modem and back on again first to see if that fixes it
May 26, 2010 | Sony Playstation 3 (PS3) Console
Getting error code 8001000a
__you can try this:______
I struggled setting up the wireless internet connection on my PS3. It seemed that no matter what I did, I kept getting the error message 8001000B. After reading some help materials on this website, I determined that I needed to add to my router list of allowable MAC addresses the PS3 MAC address. Once I did this, the setup was as easy as shown on the manual.
Steps:
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
__or this:___
After looking over the internet for answers I found a fix for the 8001000A and when the Playstation 3 (with firmware version 2.76) is hooked to a wireless router (in my case a Netgear WNR834B v2). Below are the steps I took.
  1. Reset your router to factory defaults.
  2. Go to Select Network Settings under Settings in the home menu.
  3. Select Easy then Wireless.
  4. Then select Enter Manually. Then enter in your SSID of your router. Then rest of the setting should be set to Automatic.
  5. However DO NOT TEST CONNECTION. Just save and turn off the playstation3.
  6. Then turn off Playstation 3 from the back of the drive.
  7. Unplug the power cord and wait 30 seconds.
  8. Plug the power cord in and turn on the Playstation 3 switch.
  9. Wait 5 seconds and turn on the Playstation 3 and it will work. You can even test your connection and it will work.
However if you want your security settings on the router then once the router settings are back then repeat steps 2 through 9. Hope this works for all. I do not think replacing the unit is the answer. Any question just let me know.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Wont let me sign in.says error 8001000a and says
Have you tried to test your connection. Or maybe you should turn it off from the back, along with any other device you have plugged into it, wait 2-3 minutes, and turn it back on. Hope this helps
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Error code 8001000a
delete cookies,cashe, and authenticate files and reboot system, This will fix ur Prob
Feb 17, 2010 | Sony PlayStation® 3 (60 GB) Console
Connection problem for ps3 internet
cant you attach the old wireless router to one of the expansion slots in the new wireless router and have the old one for ps3 only and the new one for everything else
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Error 8001000A.
you may need to add the ps3's mac-adress, ip and so on in your router.
Oct 01, 2009 | Sony Playstation 3 (PS3) Console
Error code 8001000A, when hooking up wirless internet
try a different wep code because it might be the wrong one and if it isnt the wrong one put in the code but add 6992882
Feb 15, 2009 | Sony Playstation 3 (PS3) Console
Wireless
what ever the password is for the wireless router when it was set up for 'wireless'. If you are using the wirless router you need to choose which network you are logging onto and then put in the password to get access to it. If you do not know it ask the person who set up the router what password they used.
Oct 26, 2008 | Nintendo Wii Console
After hooking up wireless router model #WRT54G2, all I get is a error code that my either net cable is unplugged when it is connected per installation CD (checked it numerous times) Is my cable defective?
The problem is one of three things. The order of replacement is as follows:
1. Bad Cable
2. Bad Network jack connection
3. Bad router
When items are functioning properly you will have connect LEDs on the network card and the router. Also ensure that you TCP/IP setting are set to obtain an IP address automatically
May 19, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
250 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
