You must check serial number on your TV. Some serial numbers begin with DS1, DS2, DS3, or DS4. Than match your boards. As of now...I don't believe you have the correct board. Thanks for asking, Matt of Martins TV Repair, an authorized Philips Service Center.
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
In some models of LCD TVS; the backlight inverter will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, it can't be replaced. In this case; a panel replacement is the only repair.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Each set is somewhat unique in terms of parts, could you please update this with the model number. With that I should be able to rpovide you with details.
Thanks,
Dan
