Back to:
Tags:
Intel Celeron D 330 2.66G CPU
Gigabyte mother board
posted by frankybo0412 on Nov 23, 2007
I am trying to put a intel celeron D 2.66 processor in a ga-8st667 mother board but the machine will not start.Are they compatiable.
thank you
frank
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 01, 2007
Helpful (85)
gamebunny
Rank:Master Master
Rating: 86%, 39 votes
hi reason y it wouldn't start is because the 2 is not compatible, what u can do is get a Intel P4 not a celeronD check the socket size and make sure that it correspond with the board that u have. The board that u have uses a 478 socket size so u need to get a processor with the same socket size ok... that should do the trick
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on gigabyte mother board:
I don't want to Accept this solution
Can you Help with these Processors problems?
Processors
i am running vista home basic on my compaq presario, it...
Processors
I have a Toshiba Equium M70 337 laptop. I want to install...
Processors
hello when i go into add/remove programs the window opens...
Processors
i have this old dell pentium III that i'm trying to...
Processors
can i up gread
Loading problems.
Repair Service
Find Processor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
