Question about Refrigerators
Beverage Air refrigerator not cooling well
I have a beverage air countertop refrigerator (glass merchandiser circa 1991) and it's not getting below 55 deg. Here are some symptoms... Thermostat is set on high and it does not cycle off it just runs and runs trying to get cold. There is a good seal around door. Condensor is on and hot, can touch it without getting burned. Condensor underneath looks like it had been refilled with refrigerant in the past, there is an extra port in the condensor. Condensor fan makes noise, imagine bearings bad in motor, still spins freely and fast, needs replaced but probably working for now. I took off cover from inside and felt the coil on inside, not super cold prob 55 deg. Is it likely the condensor is worn out or low on refrigerant? It is labeled for R12. Should I try and fix it? Seems like if its a leak it may be worth it, if its the condensor it will be too expensive. I can take it to a shop here but $80 to check it out. Thanks
  • leewinkler Jul 29, 2009
    I meant compressor when I said Condensor
  • 286 Answers
Just a warning about r12 systems. There is no more r12 unless you have a recycled. If the shop has r12 or they might be able to use something else on it. But it does sound like a leak in the system.
Might not be worth a sealed system repair.
Posted on Jul 29, 2009
Water dripping on everything inside - seems to be collecting on outside of upper fan housing. Drain hose is not clogged.
You need to shut it off and get the ice to melt off the coil. With that accomplished, put a thermometer inside and don't put the temperature below 37 degrees f. Hope this helps and good luck.
Jul 05, 2014 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
Water is pooling at bottom of beverage air mt45-b unit
make sure the drain line is dropping water in the drain pan, when water is dropped in the drain pan it is either evaporates to the air or is heated with an electric heater in the pan, if this is the case make sure the heater is getting how if not find out why!
Aug 01, 2013 | Carrier Beverage Air® MT45-W-55 /...
Model mt 17-54 will not cool
Go to page 10 of this PDF=> MT Merchandisers (MT Series) If you do not have Adobe Reader Click=> HERE For Customer Service at Beverage-Air=> HERE Go through pg.10 and that should give all answers you need, Good Luck, Sea Breeze
Feb 23, 2012 | Beverage-Air MT45 Beverage Cooler...
How do I fix a noisy fan blade. Can't figure out what it is hitting. The noise doesn't happen till fridge is on for few minutes.
oight be caused by build up of ice or unbalanced/worn fan, try defrosting it. if you still have problem have the fan checked out
Jun 02, 2011 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
Refrigerator not cooling
http://www.beverage-air.com/Main.aspx?pid=57&tab=58
go to this web site and find your exact manual. If you have any questions drop me a line
May 14, 2010 | Beverage-Air BM23
My bev air mt12 runs but does not cool ...the compressor runs but the temp remains the same
AFTER PULLING THE COMPRESSER @ EVAPORATER TRAY THE SYSTEM BEGIN TO PULL DOWN THE TEMP IMMEDIATELY AFTER APPROXIAMETLY 40 MIN I HAD A DROP IN TEMP OF 22 DEGREES GOING FROM 80 TO 38 IT THEN BECAME EVIDENT THAT I HAD A PROBLEM WITH FREE AIR FLOW ACCROSS THE COMPRESSOR & EXITING THE BACK OF THE UNIT. THE UNIT SITS IN THE GARAGE WITH A 4 INCH CONCRETE CURB BLOCKING THE FREE FLOW OF AIR MOVEMENT . SO RELOCATING THE UNIT WAS THE SOLUTION..
Feb 17, 2010 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
