Question about Frigidaire Side by Side Refrigerator 26 Cu. Ft. FRS6R4E
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The frez work just fine. The refrigerator side fan not blowing. I turned the temp knob to zero, then pit on colder. I heard slightly the fan engage at a real slow motion, then stop and a couple of clicking noise. I only had the refrig for a year and 4 months
  • 5 more comments
  • oceanrunner Nov 23, 2007
    No, there is no frost build-up in rear. The fan for freezer working just fine.
    Also, I just took the inside rail (plastic cover house the wires) where the damper located off. Just drop the plastic housing to see if the damper close to let the air through. I discovered when I open the freezer door, some cold air travel from the freezer into refrig. When I shut the freezer door, the cold air stop traveling through?????????
    Ok, I discovered the problem. I checked the coils inside the refrig section. I noticed the coils were frozen. I cut it off, and used a hair blow dryer to defrost. Vola! its back working again. You you suspect the defrost themo not working? How can I correct this problem from occurring again? What broke?
  • oceanrunner Nov 28, 2007
    I did the 5 times click on the light switch. It appeared the compressor and fan turned off. I waited an hour, still same problem
    I checked the damper, and its working fine. As far as the blockage,nothing blocking at the vent. Right now its working fine. Its blowing with the freezer door closed
    No, I disconnected it and defrost the coils with a hair dyer. Once done, it started working correctly.
    Thanks, you mean in about 4 days...(smile) What is the bimetal?
  • 447 Answers
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Posted on Nov 23, 2007
  • 4 more comments
  • joey  shearer
    joey shearer Nov 23, 2007
    Pull off the lower back panel in the freezer behind the lower shelves and check the coil behind for frost buildip. Also check the lower return air duct (its located beside the coil going into refrig side) for any blockages.
  • joey  shearer
    joey shearer Nov 24, 2007
    While it is likely that the thermo failed it could be the ADC control board, or the defrost heater. You will need an ohmmeter to check the thermo (when the temps are stabilized) and the heater. Does your refrig have 2 thermostats on the control panel?? If so if you push the Refrig light switch 5 times that puts the ADC control in a forced defrost mode. The compressor, fans turn off and def heater is energized through the thermo.
  • joey  shearer
    joey shearer Nov 28, 2007
    The return air duct is blocked by ice if you still feel air when the freezers open and not when its closed. I had 2 calls where this was an issue today. Return duct is behinnd the crispers close to the water tank. looks similar to opening behind damper
  • joey  shearer
    The ice in the returen finally did clear itself than. Since the board did go into defrost as you described the most likely repair would be the defrost bimetal. Also of course the def heater itself could also be bad.
  • joey  shearer
    Yes but im trying to convey to you is that the unit is probably not defrosting by itself (its not normal to have to use a hair dryer to defrost it) aits got its own heater for that. It may not be working proper and in a few weeks the frost may come back.
  • joey  shearer
    ok first test-- the bimetal is the switch that has probably a blue and a light blue wire and its clipped to a freon tube at the top of the coil. You have to test it when its cold--before you defrost it. You remove panel quickly while ice is still on evap. Then press FF sw 5 times to put into defrost. The heater probably wont get hot. Next splice the wires to the bimetal. If it heats -- thats what it was. If it still doesnt then......try that first. Oh one other note dont leave bimetal bypassed. Seperate and insulate the two wires until u have a new bimetal.
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
When does the thermostat need to be replaced in my refrigerator
Test the fan for continuity. If its OK check the power supply going to the fan if power is there, fan is bad, replace it. Fan blows the cold air to the fresh food section, if its not working very little cold air gets to that side, thats why its so hot in there.
Aug 17, 2014 | Frigidaire Refrigerators
Frigidaire gallery refrigerator freezer and fridge are warm, no air blowing out can hear fan in back, back of freezer wall is iced over. What's wrong with it and how do I fix it?
Replace the timer. It is located in the refrigerator side on the wall behind the temp. contol knobs. Pretty simple job. I has the same problem and a repairman wanted to change the thermostat and the heaters for a few hundred. He never mentioned the timer. Talked to someone else and they suggested the timer and they were right. Haven't had a problem since and it's been a couple of years now.
Sep 17, 2013 | Frigidaire Gallery GLHS66EJSB Stainless...
Refrigerator runs warmer than usual
Hello Sam Hagar - Is your refrigerator a side by side? If so, and if the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction or an issue with the evaporator fan.
Feb 09, 2013 | Frigidaire FRS6R4E Side by Side...
Hi, my sidebyside refrigerator is freezing everything even with the temp control on 0. Had electrical problem on the electric company side, lights where dimming and then getting really bright, think it...
HI,IF YOU REFRIGE IS FREEZING EVERYTHING ,AFTER POWER SEARCH.UNPLUGED FROM POWER FOR 1MIN.PLUG BACK TO POWER IF PROBLEM CONTINUE,PROBABLY BAD CONTROL BOARD AND AIR FLOW DAMPER ASSY..
Jun 05, 2011 | Frigidaire Side by Side Refrigerator 26...
The temp in the refrigerator is fine. The freezer is not freezing. We have cleaned the coils. What next?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 20, 2011 | Frigidaire FRS6R4E Side by Side...
Freezer is cooling fine, but fridge is not cooling properly
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 12, 2010 | Frigidaire FRS6R4E Side by Side...
Refrigerator 1/2 temp will not get warmer than 28 degrees
try and replace the thermastat control.
turn both knobs to the off position and listen i the fridge for the cold air damper to close it is located top left side rear of the cabinet in the fridge if the door does not close then you may need to replace the damper
Apr 13, 2010 | Frigidaire FRS26R4A Side by Side...
Freezer side is working fine refrigerator side not working.
THERE IS A FAN THAT BLOWS THE COLD AIR TO THE FRIG SIDE!
Nov 03, 2009 | Frigidaire FRS23R4A Side by Side...
Refrigerator
yes on top of the compressor
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Open Questions:
Frigidaire Side by Side Refrigerator 26 Cu. Ft. FRS6R4E Logo
203 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
