Question about Refrigerators
Freezer does not keep food frozen, ice maker does not make ice. Refrigerator temp seems warmer.
  • 99 Answers
There is a temperature control in either the fridge or freezer, that just needs to be turned up to a colder setting it sounds like.
Posted on Jul 29, 2009
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Temp set at 5(as always) but food in the refrigerator is freeezing. Ice maker and water distpenser do now work. just started happening.
Try unclogging the drain line for the freezer. What seems to be happening is your refrigerator is working too hard to keep the temperature that it reads inaccuately. Usually a light defrost will do the trick , sometimes a longer defrost or one using warmers...don't be too tempted to use anything like a hair dryer for safety reasons.
Make sure you keep your frig door closed and use the frozen food in the frig to hold temps down.
Good luck.
Mar 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Hot house,, effect on freezer temperature
cork....this is interesting. First, I'm going to suggest that you remove all the ice from the unit and clean it. Use a hair dryer to melt the ice and then make it dry. Reassemble. Many of these units allow you to remove the ice maker bucket. Don't forget to clean that up. There is a way on many of these units to turn off the ice maker...If you leave it too full, the defrost cycles will melt the ice together causing your problem. On my Kenmore, I keep the bucket about half full. Generally, the preset temp should be 40 in the fridge and 5-10 in the freezer. If either of these is warmer, you have shorter food life. By the way...Mom will feel warmer if she has a humidifier in the house. Get the cold vapor type.
Dec 19, 2007 | Kenmore 53642 / 53644 Side by Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
