Lightening hit house, Win XP computer died, Computer started working at full capacity after two days, then computer died again. Eset Nod shows cannot open most files. Will using system restore help bring computer back to life? after lightening (when it was working) Eset found no virus. Ran defrag, still no problems detected. Boots up now- but Eset says shredder problem blocking programes (NOT SPY SHREDDER)
SOURCE: My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
SOURCE: what is windows xp wdf01005
Wdf01005 is the Microsoft Kernel-Mode Driver Framework Feature Pack 1.5.
You might have got it through Windows Update.
SOURCE: unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
SOURCE: External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
SOURCE: w34oua gateway system restore download
You need to solve the overheating problem first. Shut down the computer, unplug it and remove the bottom cover. Clean the dust and lint. Blow compressed air from a compressed air can. Re-install the cover and restart your computer. If you own a laptop, the fan should be running ALL THE TIME, sometimes slow, sometimes fast buta always running. Check the the fan is blowing air. If it is not, you'll need to replace it before doing anything else.
