Question about Vehicle Parts & Accessories
Keyfob not working in my 2001 Jeep Cherokee Limited
When I bought my Jeep about a year ago, the keyless entry keyfob worked perfectly. Recently, it stopped working. Thinking the problem was a dead battery, I let the local auto parts store replace the battery with a fresh one to no avail. can anyone help? Thanks!
  • 631 Answers
Could be the battery in the Keyfob. Also could be a fautly keyfob itself.
Posted on Jul 29, 2009
2003 Hyundai Tiburon GT. Driver door is stuck locked. The lock moves but the door will not open. The passenger door lock works fine
There are rods inside the door one has disconnected will have to remove door panel to fix it.
Nov 16, 2016 | Cars & Trucks
I recently had body work done on my car. Now my keyfob doesn't work and my tire pressure monitor doesn't work. I have already replaced the battery and attempted a reset of the keyfob. No luck. I do...
Take it back to the body shop an have them reset everything . Nothing you can do .
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Program Key Fobs.
Select Invalidate All.
Follow the scan tool on screen instructions.
Feb 14, 2018 | Cars & Trucks
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Thanks.
Nov 28, 2012 | Peugeot Cars & Trucks
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
Diagnose keyless entry system of 1997 Cherokee
Before replacing any Relay. Try disconnecting the negative side of the battery for at least 2-minutes to de-energize the security system, re-setting itself. The reconnect the battery and try your security (and options) system again.
The only other big question that you will have to know: is this a factory installed security system or an aftermarket security system? This makes a difference in security systems, relays etc.
Dec 27, 2009 | 1997 Jeep Cherokee Country
Vehicle Parts & Accessories Logo
203 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
