Question about Lexmark X342n All-In-One Laser Printer
Replaced the photoconductor, but still get the message
We've done as we should, replaced the unit, and held the stop button for the required time, but we still get the message saying to replace the unit.
  • ilclark Jul 29, 2009
    Thanks - thats fixed it!!
  • 65 Answers
Make sure the front cover is OPEN when pressing the STOP-button for 3sec+. Then close the front cover.
Posted on Jul 29, 2009
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
Hi Ya! I was looking out for the solution of the Epson 1400 printer having black toner shows pop-up message; which displays "Consumables near end of service life". "Prepare the following...
If a consumable product reaches the end of its service life, the product stops printing and displays the following messages in the LCD panel or the window of EPSON Status Monitor 3. When this happens, the product cannot resume printing until you replace the depleted consumable products.
The photoconductor unit comes to the end of its service life. Even if this message is displayed in the LCD panel, you can continue to print for a short time by pressing the B&W Start or Color Start button on the control panel. The message in the LCD panel changes from Replace Photoconductor to Worn Photoconductor.
Mar 22, 2011 | Epson Stylus Photo 1400 Printer
REPLACE PHOTO CONDUCTER ERROR
photoconductor is the main unit in the machine. it has done its life of 60,000 copies so it requires replacing. if you open the front cover. the photoconductor unit is locater beside toner supply unit.
Dec 13, 2010 | Ricoh Aficio MP 161 Black and White Copier
I have a Lexmark E 352DN it was asking for the photo conductor to be replaced,I have done this and I am getting the same message. Any suggestions please
press and hold the select button and the back button
Power on printer when you see something in the display release
you should see CONFIG MENU use arrows till you see Reset PC Cnt. Press select see Reset. hit select should solve your problem
Enter the printer's Configuration menu:
  1. Power off the printer.
  2. On the printer's operator panel, press and hold the select button (pattlnk_11202006_2142-select_button.jpg) and the back button (pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif).
  3. Power the printer back on while keeping both these buttons held down.
  4. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons.
  5. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen.
Press the right arrow button (pattlnk_4122007_1837-right_arrow.jpg) until you see Reset PC Cnt. Press pattlnk_11202006_2142-select_button.jpg once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg again.
The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif once. 4
Press pattlnk_4122007_191-left_arrow.jpg or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
If the counter has been reset correctly, the printer should return to a Ready prompt. 5
If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that:
  • The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer.
  • The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer.
Jun 23, 2009 | Lexmark Lemark E352DN Laser Printer
Replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Jun 03, 2009 | Lexmark E350d Laser Printer
I have a Lexmark E352dn printer. The screen showed that the Photoconductor needed replacing which I have done. However the screen still shows " 84 Replace Photoconductor " I have removed and...
the problem is that you need to reset the counter of the photoconductor unit. From the official site of lexmark, i find this solution.
2 Press the right arrow button (pattlnk_4122007_1837-right_arrow.jpg) until you see Reset PC Cnt. Press pattlnk_11202006_2142-select_button.jpg once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg again.
3 Press pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif once. 4 Press pattlnk_4122007_191-left_arrow.jpg or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
Dec 02, 2008 | Lexmark Office Equipment & Supplies
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Clearing message after "replace photoconductor kit" message came on
To reset the photoconductor page count:
  2. While the printer is off, press and hold the Select (pattlnk_1262005_1956-enus20772_selectbuttonicon_t64x_en_us.gif) and Return (pattlnk_1262005_1950-enus21096_returnbuttonicon_e340e342_en_us.gif) buttons on the operator panel.
  3. While keeping both buttons held down, turn the printer back on. Keep holding down both buttons until the printer screen displays Performing Self Test or CONFIG MENU.
  4. Release the buttons when you see either of these messages.
  5. If Reset PC Cnt does not then appear on the screen, press the left or right menu button until it does.
  6. Press the Select button once. The message Resetting PC Cnt Value should briefly appear on the screen, indicating that the photoconductor page count has been reset.
  7. When the display shows CONFIG MENU again, power off the printer.
  8. Wait five or more seconds and then power the printer back on. NOTE: Do not hold any buttons down when powering on the printer during this step.
    The photoconductor page count should now be reset. At this point, it is recommended that you print a menu settings page to confirm this. Do the following:
    1. With the printer at the Ready status, press the left or right Menu button until UTILITIES MENU appears on the screen.
    2. With UTILITIES MENU on the screen, press the Select button once. A new menu should appear.
    3. If Print Menus is not displayed on the second line of the screen, press the left or right menu button until Print Menus appears.
    4. Press the Select button once. The message Printing Menu Settings should appear on the screen and the printer will print out one to three pages of printer settings.
    5. Look for a heading labeled Cartridge Information on one of the menu settings pages.
    6. Under Cartridge Information, look for the word Photoconductor. Confirm that the level of the photoconductor says OK or is close to 100%.
    7. If the photoconductor is still reading low, try printing 10 - 20 more pages.
    8. Print the menu settings page(s) once more. Confirm that the photoconductor level is now at OK or close to 100%.
    9. If the photoconductor continues to give a low reading, repeat this entire procedure again from the beginning to reset the counter once more.
    10. If the photoconductor reading is still low after two attempts to reset the counter, the printer may require service.
Jul 28, 2008 | Lexmark E342n Laser Printer
Lexmark X342n All-In-One Laser Printer Logo
239 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
