Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
  • 117 Answers
If you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Posted on Jul 29, 2009
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
Why is there no hot water, only cold water coming out the mixer valve?
Sounds like the screen is plugged or the check stop is not working correctly
May 28, 2014 | Grohe Grohtherm Thermostatic Rough-In...
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
I'd like to install 1 shower had and one hand held shower. What do I need to have ?
well you can do a 3 way shower valve , or a mixing valve with 2 control valves. or you can do just to regular shower valves one for each of the heads you want one for the rain and one for the shower head. this way is cheeper and you can have one on hot water and the other cold water or the other way around or both the same temp.
Apr 26, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Hot water not as hot from rain head as other outlets
i'm quite sure you shower valve has an adjustment on handle that allows more hot water into the mix,........it will tell you how in the paper work that came with the valve,....good luck, cracklin joe
Jan 06, 2010 | Grohe Grohtherm Thermostatic Rough-In...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Adjusting water flow
if you are using a mixing valve it is pre set so as to not burn your self but if you wish to set it on the dial depending on which one you have, some are flat tip screw driver some have plastic cap on it turn on the water and set to your desired temp by turning clock wise or counter clock wise
Apr 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
HOW TO ADJUST A MODEL 34122 gROHE VALVE
there should be a flat head screw on the mixing valve turn the water on and turn it to the desired temp,, it is letting to much cold water in , if this does not work replace the mising valve
Apr 11, 2009 | Grohe Grohtherm Thermostatic Rough-In...
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
1,950 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
Craig Butler
Craig Butler
ray gallant
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
