SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
I hope that helps.
SOURCE: my westinghouse SK-26H730S have no power, no
my westinghouse SK-26H730S has the same problem. it won't turn on at all
SOURCE: My sk-26h730s turns itself off and on and turns
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
SOURCE: i have a Westinghouse 26
I have a 26 inch Westinghouse lcd and when I turn it on the blue light comes on showing there's power, but the screen is blank.
SOURCE: They did not include the
Cheapest place to buy cables would be from monoprice.com
If you would like I can give you a list of suggested cables to use for the best picture/sound. I'd just need to know what the make and model of any other equipment you are trying to hook up to the TV is. i.e.
Sony DVD Player: DVP-D2700
Denon Reciever: AVR-391
