Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Stops midway on side of pool and although pulsating stops it stays there. If power is turned off momentarily it drops to bottom of pool and continues cleaning when power is switched back on.
  • Dale Cobb May 11, 2010
    is there a return line on the wall that it might be hanging up on?
  • 106 Answers
Sounds like foot pad is worn, not allowing enough clearance to unit. Replace foot pad.
Posted on Jan 14, 2010
Why won't it sink to the bottom?
Air trapped in the unit. They do not float unless air is trapped. Turn upside down under water to relieve trapped air.
Jun 23, 2015 | Zodiac Baracuda G2 - In Ground Suction...
Creepy not working good suction it sticks to the bottom of the pool and wont move
If it is an actual Kreepy Krawler that Pulsates and you have good suction then you should look k side and see if something is stuck inside the diaphragm or if the diaphragm is torn then it has to be replaced.
Jan 01, 2015 | Pool & Spa
What can i do to get my Zodiac Kreepy Crawley to submerge under the water to clean the bottom of my pool
Check to see that the hose weights are attached. There should be a weight in the middle of the fist 3 sections of hose from the cleaner.
May 16, 2014 | Universal Kreepy Krauly In-Ground Pool...
My creepy crawley will not pulsate, or does for 5 minutes then stops pulsating but keeps on sucking. I have read a few complaints and from what I can gather, I need to replace the flapper valve. What is...
ok first of all the flapper is located right in the center at the bottom of the creepy crawley. Pull it out of the pool turn it upside down and you can actually move it with your hands and it will feel like it loose and not really connected. Anyhow check in the mouth - opening for any kind of obstuction (leaves,twigs or anything foreign that may be causing it to fail. There can be something flopping around inside causing it to work sporadic or the flapper may need replaced however I doubt that. Next you need to check your circulation. Is there to much suction? this would cause it to stay in one spot and not move. Do you have an air leak causing the pump to lose prime and then regain it over and over? There are two ways you can check for air. At the pump basket - if you have a clear top can you see bubbles or on your return lines to the pool is there bubbles coming out? To much circulation and poor circulation can cause the creepy to do weird things. When was your filter last cleaned? Is there the required amount D.E. inside? Have you backwashed the filter at all? The last thing to check would be the hoses connected to the creepy crawley. Some hoses become loosly connected and start sucking air. Some hoses rub along the plaster continuously in the same spot causing holes. Although unlikely, poor water chemistry - chemical damage can cause hoses to deteriate over the years.
I hope this helps. Please feel free to submit any further questions you may have and I will be glad to answer them for you. Good Luck!!
Dec 08, 2010 | Universal Kreepy Krauly In-Ground Pool...
I have replaced the diaphragm on my Classic. I have even replaced the filter sand. There are no apparent tears in the pipes, yet the cleaner runs for a few minutes and then stops dead, not pulsating. The...
Use Pool Pulse to ensure proper flow. It could feel ok on your hand, but you need very precise pressure to power these pool cleaners. If you are not familiar with how to use the Pool Pulse feature, take a look at the users manual below. They have a step by step guide to this feature.
http://www.baracuda.com/resources/manuals/G4W83408.pdf
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Cleaner is floating on top of pool
First, remove all of the air from the cleaner head and stop all air from entering the pool2_bing.gif through the return lines. Also, if the head and hose are covered with bubbles, give the hose a good tug. This will release the air bubbles and allow the pool cleaner to settle son the bottom of the pool. Also, the cleaner head may actually be being lifted off the bottom of the pool by the hose or the pressure in the return lines. Make sure that the hose stays untangled and the pressure from the return lines is not too low (not enought pressure to power) or too high (too much pressure that cause the unit to lift off the floor).
Apr 20, 2010 | Hayward Navigator Pool Cleaner
It pulsates; but pretty much stays in one spot
check your diaphram for a tear near the plastic ring that hold it on the tube
Jul 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Prints 2/3 of the way, stops, continues, bottom is faded
It sounds like you need to replace Toner Cartriage
May 19, 2009 | Samsung ML 2010 Laser Printer
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
165 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
