SOURCE: Panasonic telephone system KX-TD816e
re:reset On the side of the cabinet near the power switch is a reset button and a SET CLEAR switch. Turn off the system, put the switch in CLEAR and push the reset button with a pointed tool. When the red light flashes and within 10 seconds, put the switch to SET.
I'm hoping you have a programming manual even though you must not have an installation manual.
Carl
SOURCE: i need to reset to the factory set in fax panasonic KX-FT983
first you have to clear it's make & model
SOURCE: hello , \r\ni call from iran . I WANT reset the
Hi
SOURCE: my machine is not printing
Mine did that when the drum was getting old and also when the inside of the scanner glass got dirty, Q-tip and alcohol fixed the scanner glass, Yours doesn't have a drum though it has a scanner window. so you just need to open it and find the window and do s little clean up. No more copies of dirty pictures for you though :-)
SOURCE: I am receiving an error
Your printer is signalling that it is out of ink and that you should put a new ink cartridge in. Without a new ink cartridge it cannot print the pending faxes.
