i PURCHASED A wIfI REPEATER FROM tmART.COM. i PLUGGED IT IN AND HAVEN'T NOTICED ANY WIFI PROBLEMS ANYMORE. bUT, hOW WOULD THE AVERAGE PERSON CHK IT? iT'S YOU CALL, IF YOU WANT, GET IT. i THINK i PAID 23.00 FREE SHIPPING. gOOD LUCK... OH, vERIZON DOES HAVE A NETWORK EXTENDER BUT IT IS EXPENSIVE +$240+. i WOULD PUT LONGER aNTENNAE ON THE ROUTER, WORSE COMES TO WORSE. gOOD lUCK. -nED-.
Hello Sir !
sir you can only use free wi fi if your phone supports wifi and you also have a wifi device in surroundings.
if you dont have a wifi device then keep trying for searching ifi on your cell phone on different locations if the search result shows you some wifi connections then you can connect that connection and can use free wifi
Thanks
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
Purchase a wireless router that fits your needs and price range.
Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
5
Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
6
Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
7
Click on "Properties."
8
Select the "Wireless Networks" tab.
9
Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
10
Click on "Configure" when you see your network's SSID in the "Available Networks."
11
Enter your network's SSID and WEP key.
12
Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
check your laptop wifi , are you sure that is on, search wifi , you must saw wifi ap in your windows, so click connect with wifi that is choose, if your set is in automatic ip gateway and dns server , you must take on your dhcp mode in your router, if itsn set your ip in permanen value
