Question about Saws
Where can I find a blade clamp for a STSE 250 jig saw, none of the local tool suppliers can help me
    Sergeant:
  • 384 Answers
Go to an industrial supply store and purchase a shaft collar of the proper ID dimension
Posted on Jul 29, 2009
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Jig saw catching and jumping using new vermont american blades
try one with more teeth and do not force it into the wood
May 14, 2012 | Vermont American Tool Company Saws
Instructions on removing blade from jig saw model dw933
To remove a blade on this saw, lift the knob on the top of the saw and rotate the knob counterclockwise. This will open the blade clamp. The blade should slide out. To install a blade, slide a blade in, being sure the back of the blade fit against the support roller. Clamp the blade in place by turning the knob on top of the saw clockwise until you hear a clicking sound, then push the knob down.
Hope this helps.
Apr 26, 2011 | Garden
I have an old dremel 2 speed 16 inch scroll saw. The motor appears to work, but I can't figure out how to put a new blade in it! Can you help me?
a standard coping saw blade or a blade made for the saw - one end is clamped in the piston, the other end is clamped in the upper arm. look for an allen wrench set screw.
Oct 13, 2009 | Dremel Saws
Not sure how the blade seats in saw pneumatic bosch jig saw i can get it to go in but the blade seems to wander and seems to be unstable
do you have the screwdriver that came with the saw? if not you need a longer straight slot screw driver and it must be ground down to fit into the blade clamp tightener. it is a narrower than usual screw driver. I lost mine and had to custom make one. good luck.
Sep 14, 2009 | Bosch 7561 - 118 Pneumatic Cutting Tools
Jig saw model 7580 type 4, replacement for blade clamp
There is no model 7580 Jigsaw. The only model close to that I can see would be the 7588 Type 4. Unfortunately that part is unavailable for this model. You may want to contact your local Dewalt service center and see if there is a substitute for that part.
Sep 05, 2009 | Black & Decker Saws
Borrowed a B&D jigsaw model 7571 want to know how two use the other speed and how to put the blade in properly....does not seem to cut without great force....Cindy
arrowred.jpgExclusive Quick Clamp® tool free blade change provides easy, tool free blade changes
arrowred.jpgAccepts U and T shank blades for use with your preferred blade
Aug 15, 2009 | Black & Decker Saws
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Saws Logo
70 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
