Question about Plumbing
Hello, I have just changed a swimming pool pump, and the new one does not want to start without a 'kickstart' of spinning the vanes. The old pump had a 'starter'within the electrical connection bow, whereas the new one neither has one, or a space for one. There are six terminals within the connection box in two banks of three, and neither of the two left hand terminals have any connection to them. Would there be such a thing as an external starter, and where does it connect in to? Your help would be much appreciated.
    President:
  • 2,559 Answers
Yes and usually to 2 brown wires,If you don't have 2 browns please try and post a picture or more details such as motor model,brand,size,etc.....
Posted on Jul 29, 2009
Why won't my pool pump start?
Your pump is dead, replace the motor with a new one. Or get a variable speed pool pump, itll save you on your electric bills
Jul 17, 2014 | Zodiac Jandy PlusHP 1.0 Hp Full Rated...
Swimming pool motors
If the pump is turning on/off like that then there is something going on in side the motor.
It does that when the motor over heats.
RodUS Parts Center888-521-6183
Feb 14, 2013 | Pool & Spa
If AO Smith 1.5 HP pool pump mootor is turning the wrong direction could that be the reason for not priming. If so how do you change the direction of spin?
these motor have been known to do this, you could have the capacitor checked or replaced, it might be a bad motor.. i would look to see that the shaft seal is good (new) and no suction leaks and that the pump has been primed.. if not its time 4 a new shaft seal.. it only takes a short time to burn up the shaft seal
Feb 19, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Pump motor not operating
The pump is defective and will need to be repalced.
May 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward Swimming PoPump is 4 years old - when I opened pool, pump
it you've inspected all the wiring for possible shorts, the most likely problem is that the motor has developed a short in the windings. You may have to replace the motor. First check for loose connections and make sure the wiring going to the pump is good. Also, check the start capacitor, should be under the hump or under the end cover on the motor. If it's bloated or leaking, it's bad.
Most likely the winding have a direct short.
Apr 05, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
