Question about Whirlpool GU2455XTS Built-in Dishwasher
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Posted on Jan 23, 2010
  • 636 Answers
Try shutting the breaker off for it in your breaker box ,should reset unit. hope this helps you out.
Posted on Jul 29, 2009
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirpool dish washer model #Gu2400 -dishes are clean but clean light keeps flashing
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Whirlpool Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400 dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Dec 23, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
GU2400GTX
electronics fail most often when new. would not be surprised to see you have a logic board failure.
a new unit should not have any issue that would contribute to a malfunction, so looking for door switch problems or motor problems seems like a waste. call the service center for the unit.
good luck
mark
Apr 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2455XTS Built-in Dishwasher Logo
1,141 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
