Question about Refrigerators
Condensation forming on the top of the refrigerator. Freezer seems to be operating fine. Try defrosting the refrig - ie. turn it off??
  • 286 Answers
Usually you have a mullion heater around the refrigerator. That stops the sweating on the outside of the refrigerator. Make sure your energy saver button is off. When the switch is on the heater is off.
Posted on Jul 29, 2009
I have a Siemens KG..V fridge/freezer - seal
This heat is coming from the mullion heater that wraps around the opening of the freezer and refrigerator door openings. This heater is used to eliminate condensation forming around this area. If you have a moisture switch or summer/winter switch, set it to the off or winter position. This should turn the heater off.
Oct 20, 2014 | Refrigerators
This reffrig freezes in the freezer but does not cool well in the refrig. whats wrong?
The most likely cause is that you have a defrost system failure or the evaporator fan is not operating. If the fan is turning it is most likely operating. To troubleshoot the defrost system, here are some links that should help you: The defrost heater is easy to check with an ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Jun 16, 2011 | Roper RT14DKX Top Freezer Refrigerator
The refrigerator portion of refrigerator is not working but the freezer is working fine.
Look in back of freezer and see if you see ice formed. If you do, it's in the defrost timer, thermostat or heater.
If it has no ice-check the evaporator fan motor and make sure it's running.
One last thing: check and make sure the refrig and freezer is at factory settings. Sometimes people turn them up or down.
Nov 26, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Freezer seems to be working fine. refrigator does not seem to be cold enough
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | Frigidaire FRT17G4B Top Freezer...
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm refrigerator compartment
We had similar problem. Found the interior lights of refrig. were not turning off. Found out this was a recall problem and was fixed by sears for free.
Jun 21, 2009 | Kenmore 73503 Stainless Steel Bottom...
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Freezer temperature
sounds like a defrost problem. could be defrosting too long making the freezer warm up
Oct 30, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
221 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
